Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - broken block 350 starter bolt hole
Old 02-03-2013, 08:16 AM
Greg T's Avatar
Greg T Greg T is offline
www.krusinklassics.net
Originally Posted by 1971BB427 View Post
Some mini starters can accomodate both patterns, but the block would have to be drilled and tapped for the extra hole.
He says he has an extra hole in line with the outer hole. This tells me he is using the staggered bolt pattern. A mini starter will use the two good holes and solve his problem.
