-   -   broken block 350 starter bolt hole (http://www.hotrodders.com/forum/broken-block-350-starter-bolt-hole-229036.html)
mon 01-31-2013 05:37 PM
I have a broken block where starter bolt goes in I was wondering has anyone been able to make a bracket . Does anyone know how to get around this problem? I have an extra bolt hole inline with the inside bolt hole the outside bolt hole broke out very little cast around the outside stater bolt hole. Can someone help me.
68NovaSS 01-31-2013 05:40 PM
Can you put up a picture of "how" broken it is?
vinniekq2 01-31-2013 07:50 PM
mount starter to bell housing if its a standard
1971BB427 01-31-2013 08:35 PM
Since the inner bolt hole is good, you can come off the bellhousing with a support if the block is actually broken enough to allow a nut where the threaded hole was, and then clamp that side with the bracket and a bolt.
Had a friend who's block broke on the outside hole and we did this, but actually had to grind away some material to allow room for the nut, as half the threaded hole was still there.
jaw22w 02-01-2013 07:10 AM
Years ago, I had the same problem. I built the area up by arc welding with nickel welding and re-tapped the hole. Worked just fine.
ssimpala 02-01-2013 11:34 AM
I welded a stud in mine and it's been working fine for several years.
timothale 02-01-2013 02:15 PM
mis alignment
If the starter is not properly smimmed for gear to flywheel clearance. if wrong bolts used etc . you end up with broken out holes or broken starter nose casting. Also the factory had a brace that holds up the end of the starter.
Go to the Wiki link at the top of this page, then click on engines, then when on engine page click on starters, ther are 3 or 4 pages of starter information
cobalt327 02-01-2013 09:07 PM
One solution: Adapter used to mount a starter on a broken block.
http://www.crankshaftcoalition.com/w...ptor_plate.jpg
Greg T 02-02-2013 11:03 AM
Cant use a mini starter? They can usually accomodate either bolt pattern.
1971BB427 02-02-2013 09:11 PM
Some mini starters can accomodate both patterns, but the block would have to be drilled and tapped for the extra hole.
Greg T 02-03-2013 07:16 AM
He says he has an extra hole in line with the outer hole. This tells me he is using the staggered bolt pattern. A mini starter will use the two good holes and solve his problem.
cobalt327 02-03-2013 09:51 AM
Well, most times, the outermost hole (blue circle) is the one that cracks/breaks off. It's used by both patterns. But if the black circled hole is the bad one, the mini starter idea will work.
http://www.crankshaftcoalition.com/w...tarter_pad.jpg
The OP hasn't bothered to reply to any of this, so prollably a moot point.
There are mini starters that have the straight across only or staggered only patterns, as well as mini starters that have two sets of straight across holes to accommodate both diameters of flex/flywheels.
Greg T 02-03-2013 11:42 AM
Yeah, I reread the op and he said the outside hole broke. Repair is needed.
romie martino 01-26-2014 04:53 AM
broken starter holes
I have a broken starter bolt hole where the hole holds the starter with a bolt mine is the out sidebolt housing the engine block outside threading broke off and now the starter is not turn the fly wheel. so what im going to do is drill the hole higher and put a heli coil if that dosent work ill drill through the top and put a bolt if that dosent work its going to the gravyard
Richiehd 01-26-2014 06:32 AM
Helicoil with stud may solve your issue
