get you one of the high tourque mini starters, they have 2 sets of holes in them to adjust to the large or small flywheel, using the paralell holes, about $100.00 from speedway motors.
I agree with the hi-torque stater recommendation. the only thing I would add is to go with a brand name like Powermaster. I bought a knock-off from a local starter shop and the bendix would not disengage immediately after starting. Only later did I find out that most of the mini starter knock offs do this. may not sound like much, but it was down right annoying. Also, I took it apart and discovered that the planetary gears were plastic or some form of nylon
. I then decided to purchase a Powermaster hi-torque starter and it was a world of difference. Vince |
thx for the replies guys., but i failed to mention that we were trying to fix the problem with stock parts... so, heres what i found... the older 307's, and certain 4.1 inlines run the parallel bolt hole starters with a 153 tooth flexplate. its a long story, but in short, i ended up finding out that the starter from the wifeys 307 is the same as a 79 impala 4.1 but yet there was no listing for the flexplate, so i got 1 for a 79 impala 4.1 and we got a new starter... all i had to do was pull the trans to swap flexplates and i had to modify the dust cover to fit the new setup... after i got done, it was as quiet and smooth as can be and i didnt have to do any shimming... hopefully, the next person who runs into this kind of problem, will now have some sort of solution like i found...
p.s. i added a pic of the problem so those who may not know what im tallking about will see... |
| 351m questions | elvisjer | Engine | 15 | 12-23-2008 09:08 PM |
| Another Broken Starter Nose | GoneNova/406 | Engine | 8 | 05-27-2005 04:58 AM |
| Fan hit upper rad. hose!! | mustangdude947 | Engine | 14 | 08-19-2004 03:52 PM |
| Broken ear where starter bolts in | Circus | Engine | 15 | 02-06-2004 11:13 AM |
| Starter Solution | dollybud | Electrical | 0 | 09-30-2003 06:42 AM |
