Broken bolt - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-26-2004, 01:45 PM
blacklotus's Avatar
Greg
Last journal entry: Wiring begins
Broken bolt
I have broken a intake bolt off in the head and it is broken off flush. Any suggestion on how to get it out without removing the head or major surgery. I had dipped the threads in engine oil and it just happened so it should not be stuck in thier too bad.
Greg
Old 12-26-2004, 02:13 PM
AngliaBob's Avatar
It just takes time and money
Last journal entry: Specifications
Greg,
If you broke the bolt when you were torquing the intake...Remove the intake, and you should have enough bolt , sticking out of the head, to grip with a pair of Visegrips. If you broke the bolt even with the top of the head, try to drill it and use an easyout.
AngliaBob
Old 12-26-2004, 03:03 PM
troy-curt's Avatar
Shop Owner And Troll Hunter
Use a left hand drill bit. should come right out.
Troy
Old 12-26-2004, 03:21 PM
malc's Avatar
Living At The Speed Of Life
This has been discussed here, http://hotrodders.com/showthread.php?s=&threadid=37505 different place same problem.
Old 12-29-2004, 08:15 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
take a dremel too, and cut a slot in it, and then take a straight/slotted/whatever screwdriver and get it out. Be careful not to do much to the head.
not responsible for injury to self or parts.
Old 12-30-2004, 01:32 AM
Old School Nut's Avatar
machinest & A&P Mechanic
Last journal entry: distributer housing...
weld a nut onto it, use a pick to turn the bolt, grab onto it with plyers... lotsa stuff you can do!
Old 12-30-2004, 01:37 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
broken bolt
use an easy out
Old 12-30-2004, 10:14 AM
Tazz
Your getting good suggestions....
but I would remove the intake and weld on a nut to whats left of the bolt...being careful to weld only to the inside of the nut and old bolt and not the head...Then replace ALL the intake bolts...some others may be ready to break too.
Tazz
Rat Rods Rule!
