Broken bolt - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-15-2006, 06:42 PM
Broken bolt
I have two small bolts broken off in an engine block. There are no threads showing and the bold is too small for a bolt extractor. I thought about drilling and taping the hole, but it close to the exhaust and I don't want the drill bit walking over into the exhaust. If you have any suggestions let me know. Thanks!
Old 03-15-2006, 07:17 PM
302 Z28's Avatar
If the bolts are not grade 8 then you should be able to center punch them and drill them out a little for a screw extractor. Do not use the screw extractors that look like a reverse screw thread. Use the screw extractors that have reverse verticle ribs, it is a much better extractor.
Vince
Old 03-15-2006, 07:26 PM
I've had good results using a reverse twist drill close to the size of the broken bolt. Bought a set a NAPA. Just try to startas close to center as possible. The heat and reverse twist usually brings the bolt out onthe drill.
Larry
Old 03-16-2006, 07:28 AM
302 Z28's Avatar
I have found the reverse screw extractors are of inferior metal and if the broken screw is in fairly tight they will snap off. I had one I purchased from NAPA that broke when I was trying to extract a broken brake bleeder screw. I was able to drill it out then use the other type of screw extractor.
Vince
Old 03-16-2006, 03:20 PM
New Member
broken bolt
reverse droll bit .its worked for a million times.
Old 03-16-2006, 06:50 PM
jim..'s Avatar
That 6 Cylinder Guy
Using a nut one size bigger than the bolt,position the nut over the broken end,and using stainless or extraction rod,weld thru the hole in the nut to the bolt untill they are welded together,let cool a bit and put a socket on the nut and turn it out,the heat from welding will help free the stuck bolt,I do it all the time.
Old 03-16-2006, 08:19 PM
302 Z28's Avatar
That will work great, if you have some bolt sticking out of the threaded hole.
Vince
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
Broken 4 Bolt Main Cap Teejay68 Engine 8 05-30-2005 12:23 PM
Oil Leak,whats the best way to go about fixing it? EazyDuzIt102 Engine 10 12-30-2004 08:45 AM
Broken Bolt in Block unstable Engine 34 06-20-2004 09:07 PM
10 bolt to 12 bolt 1980Impala Transmission - Rearend 8 04-25-2004 04:48 PM
