Broken Bolt in a bellhousing CHEVY. - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-18-2008, 11:40 AM
Hello guys.
I have a sbc engine that has a broken bolt in the right upper bolt hole in the bellhousing.
i was wondering what would be the best way to get it out ?
and if it would be ok too just use the other 5 bolts to bolt the transmission to the engine ?
Best regards
Old 11-18-2008, 12:51 PM
im sure ill get a lot a slag for this comment, but yes, just use the other bolts, all the load get put on the lineup dowels anyway, im saying this of course assuming your not running a 1000 horse blown small block
Old 11-18-2008, 01:27 PM
poncho62's Avatar
Wiki Edits: 5
I agree.........you can get away with one less.......but, if you have the time, yank it and fix it.........peace of mind, ya know.
Old 11-19-2008, 09:29 PM
Same here. If it's in the car, hard to get to, and not pushing major power figures or intended for serious abuse, I'd leave it alone. If it's out of the car and/or easy to get to, I'd attack it with a center punch and then a left-handed drill bit.
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Chevy 454 harmonic balancer with broken pully bolts mcdonal68 Introduce Yourself 2 07-10-2007 07:40 PM
Bellhousing bolt pattern dutch paul Transmission - Rearend 9 08-20-2005 03:38 AM
Techniques for removing a broken bolt 66Caprice General Rodding Tech 19 03-28-2005 05:48 PM
12 bolt Chevy truck pinion question Gametech Transmission - Rearend 9 03-09-2004 05:02 PM
