Broken Bolt Removal - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-22-2005, 03:35 PM
74_Chevy's Avatar
Lead Foot Hotrodder
Broken Bolt Removal
I went down to auto zone and got a new bolt for my power steering pump bracket I thought the bolt came out but it broke off it goes into the block but there is about 3 or 4 threads sticking out of the block my questions is what would be the best way to take the bolt out it's a 3/8 bolt it's to the right behind the fan below the valve cover in the front of the block next to the frame after i take the other bolt out i can move the bracket and container holding the fluid out of the way to get to the bolt. Should I use a bolt puller and drill into it? I'm not sure I can get a drill in there is there any other way to do it? Vise Grips maybe? Any help would be good thanks
Old 12-22-2005, 03:41 PM
Can you weld ?
I have taken a MIG and tacked a stud to one and then between the heat of the weld and the new stud.........it screwed right out..
Old 12-22-2005, 03:46 PM
Wiki Edits: 31
if you can easily gain access, you can weld a nut on the remaining material. you could drill and easy out it, or try the most unsucessful way of cutting a ridge in to the middle for a screwdriver.
Old 12-22-2005, 03:55 PM
74_Chevy's Avatar
Lead Foot Hotrodder
I've been welding for 6 yrs now I can weld but I don't have access to a welder right now that would be a good idea thou I'll check around i might be able to find one to use. If not then I'll have to do something else.
Old 12-22-2005, 03:56 PM
Last journal entry: Cooling...
reverse drill bit
clearance may prohibit this, but go to your local rental yard and ask for an obstruction drill. its a small electric drill that has a right angle head so it can be used on close quarters. Then go to the autoparts store, (read NAPA) and ask for a reverse drill bit. Its the same as a regular drill bit, but it runs counter clockwise, and they are usually pretty short. with this lash up, drill the center of the bolt, and the drill but will usually grab the bolt and spin it backwards, backing it out of the hole, if it doesn't spin out on the drill, then switch to an easy out, I prefer the square ones instead of the twisted type. Good luck
Old 12-22-2005, 04:01 PM
74, If you only have about 3-4 threads sticking out it probably is not enough to get hold of with vise grips. The way I do this is to take a washer that fits the bolt snugly, put it on whats left of the bolt and then while holding it flat to the block plug weld it to the bolt. Once this is done you can then take a larger nut and plug weld it onto the bolt without fear of welding it to the block, this will form a new larger head on the bolt allowing for easy removal.
Old 12-22-2005, 04:37 PM
Tazz
Having removed at least a 100 or more broken bolts...
I would weld a nut on the stub, thread the nut on if possible to the 3 or 4 threads left. Weld the nut to the bolt stub at the center of the nut now threaded on the stub. Let the nut cool just a little and then with a GOOD 6 point socket back out the stub/nut. Now your ready to clean up the hole/thread's in the block with a bottom tap. I'd suggest checking the depth of the hole with a smaller bolt to see how deep the existing threads go into the block...how far in did you screw in the bolt that broke off, you may need a MUCH shorter bolt to finish your job after you clean up the thread's. You may have to remove anything in the way of welding on the nut..I'd forget the vice-grip idea all together. Please let us know how your repair turn's out!!!
Tazz
Old 12-22-2005, 04:48 PM
Last journal entry: frame build
If you don't have access to a welder, use your propane torch or oxy-acetylene to run the broken bolt through several heating and cooling cycles. Cool the bolt after heating to a dull red (won't hurt your cast iron block , don't do this on aluminum) with PB Blaster or Kroil. Do this several times. After completly cool the last time, clean throughly with brake cleaner, put some red loctite in a nut and screw onto the remaining bolt just past finger tight. Warm it a little bit with the torch. just warm, not hot. Let set for a while, About an hour. Spray with oil again, tap with a small hammer, and turn out a bit and back in a bit. Spray with oil again and repeat. After a few rocks it should screw right out. Don't always work but it doesn't damage anything so other methods can be tried.
The best way is to weld a nut on it , heat and cool a few times and remove.
Good Luck and Merry Christmas
Old 12-23-2005, 03:09 AM
74_Chevy's Avatar
Lead Foot Hotrodder
thanks guys for the good sugestions I'll see how it turns out, the bolt that broke off was in there already I didn't put it in I think the vibration or something broke it off from the bracket that the bolt was holding on. It was getting hard to turn the wheel so I checked it out and found the bracket was missing a bolt loosing up the belt on the pully I thought the bolt came out but it broke off so now I'm fixing it. I'll try and see what will work to get it out and get back to ya thanks again guys for all the help.
Old 12-25-2005, 05:12 PM
Bolt Broken Off
Bolts that are broken off from being over tightened (Stretched until it breaks) will come out easy because the thread pressure is now released. When a welder is not available I have use a hacksaw to cut a slot across the center of the bolt and then used a flat tip screw driver with a wrench or vise grips on the screw driver shift to take the bolt out. If the bolt is broken from bottoming out in the hole, use a welder to weld a bolt to the old bolt. The bolt is still tight against the bottom of the hole. Yours should be OK to remove with a slot and screw driver.
Old 12-26-2005, 06:55 PM
74_Chevy's Avatar
Lead Foot Hotrodder
Thanks for the help guys got the bolt out. I tried the hack saw but couldn't get the blade in there very good, so just for laughs I tried a pair of vise grips and it had enough threads on it to lock on and loosen the bolt enough to get it out. Thanks again guys.
the history of chevy v8's savman1 Hotrodders' Lounge 43 03-02-2012 06:57 PM
broken bolt / thermostat housing RodFather Engine 17 01-24-2010 09:58 AM
Techniques for removing a broken bolt 66Caprice General Rodding Tech 19 03-28-2005 05:48 PM
broken bolt StudebakerMatt Engine 9 02-07-2005 08:42 PM
Fan hit upper rad. hose!! mustangdude947 Engine 14 08-19-2004 03:52 PM
