Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - broken crankshaft
Old 10-10-2012, 11:23 AM
Silver Surfer's Avatar
Silver Surfer Silver Surfer is offline
More machine than man
Last journal entry: bwaahhaahahaaahhaa
Originally Posted by atcoscrazyest69 View Post
Well i planned on gettin her all cleaned up. Ok just so i got this right if i get this kit Eagle Specialty Products B13470030 - Eagle Street Performance Rotating Assemblies - Overview - SummitRacing.com i will not need to get it rebalnced? Just put inu and go?
Thanks for all your help guys!
No. You MUST get it balanced. Internally balanced mean that you do not need a special flywheel/flexplate and harmonic damper to achieve balance. Factory SBC400's had additional weights on these components to make this work. Internally or externally balanced rotating assemblies both need to be balanced, the difference is how it is achieved. It is two different styles/methods.
You can get this kit but you must:
1) have it balanced
2) buy a new flywheel/flexplate for internally/neutral balanced SBC's, like a SBC350 . Aside from the fact of the balance issue, the link you posted uses a 1 piece rear main seal, which uses a different crank so you old flywheel will not even come close to physically bolting on.
3) buy a new harmonic damper for internally/neutral balanced SBC's, like a SBC350
