Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - broken crankshaft
  #17 (permalink)
Old 10-10-2012, 10:43 AM
Silver Surfer's Avatar
Silver Surfer Silver Surfer is online now
Advanced User
Last journal entry: bwaahhaahahaaahhaa
Originally Posted by atcoscrazyest69 View Post
The link i posted is a 2 piece rear seal? And i understand the balancer and flywheel stuff but in the link i posted it also says it is balanced so i am confused
Yes sorry, I was looking at the pic which is 1 piece, the description says 2 piece. They do come with a "balance" from the factory, but from what I hear they are not a good/accurate balance. More than likely they have a target weight/balance for each part and if they fall into a certain tolerance it is good to go, meaning the entire assembly/collection of parts you get is not holistically balanced. You can chose to trust the Chinese balance, but it is not suggested for any performance or RPM use. Low RPM grocery getter you are OK.
