Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - broken crankshaft
  #28 (permalink)
Old 10-10-2012, 06:33 PM
atcoscrazyest69 atcoscrazyest69 is offline
I understand the external balance points with 400s and 383 as it is on a 4 speed trans and i had to buy that plate that bolts between the flywheel and crank. I understand that the balancers are different for the externally balanced 400 and all the other internally ballanced motors. The whole reason for trying to make it internally balanced is i do not like having to run that balance plate. I just dont understand why the add says its balanced and a couple fellas on here are saying send all the brand new stuff out to get balanced. If i have to send it ourmt to get balanced either way then theres no need for me to get a whole rotating assembly the only reason i said id get the assembly is because it states its balanced. I just donot know what to do. But i do not want to do it again
