broken exhaust manifold bolt - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-21-2002, 07:29 PM
chevynut's Avatar
Post broken exhaust manifold bolt
I have a 327 chev that had a broken exhaust manifold. All bolts came out but one and it snapped off. The manifold must be seized to the bolt because it will not come off. I have tried heat, wax, WD-40 and so far nothing has worked. Any and all Ideas would be welcomed. Thanks,chevynut.
[ June 22, 2002: Message edited by: chevynut ]</p>
Old 06-21-2002, 09:40 PM
HotRodS10's Avatar
All Throttle...No Bottle
Thumbs up
Break out the drill, a good drill bit and either buy or rent a tap set (Auto Zone will rent it to you and give you all your money back upon returning it). Drill it out and then tap it....I've had to do it a million times, well, maybe not a million....but close. Good luck, HRS10
Old 06-22-2002, 06:47 AM
chevynut's Avatar
Post
Thanks for the reply HotRods10. Its not a bolt broke in the head, but the head of the bolt is broke off and all other bolts are out so the manifold should come right off but doesnt. I think the bolt is seized to the manifold. Thanks, chevynut.
Old 06-22-2002, 01:35 PM
johnnymopar's Avatar
Love your nails! You must be a Libra
Talking
chevynut,
i got this idea from roy @ roy's hotrod garage and it works great. Weld a bolt onto the broken bolt and turn it out. I had to do this on my door hinges. I managed to get 5 of 8 bolts this way, and they were VERY rusted. I think an engine bolt should be easier because it is generally dry.
JB
Old 06-22-2002, 06:19 PM
Tom Tom is offline
Post
drill it ! I've had to do this on a couple of fords in the past,go about 3/4 the way through then work the manifold loose
Old 06-22-2002, 07:23 PM
chevynut's Avatar
Post
Johnnymopar and Tom, Thanks for the infomation.I tried Toms idea and it worked. Thanks again.
