broken fender bolt - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2010, 06:50 PM
87fubar's Avatar
broken fender bolt
heres what i got 75 firebird the lower fender bolt that holds the fender to the body the head of the bolt broke off i try'd welding a nut on the end but didnt work at all
Old 11-08-2010, 07:22 PM
I live in Florida where in the seventies you could ride on the beach. The salt wrecked havoc on the lower fender bolts and I fought a many of them. If you can get the fender off by removing the rest of the bolts then you can repair the problem. Another approach remove as much of the bolt as you can with a grinder and then pry the lower part of the fender down and over what's left of the bolt. Once you get it out use a block of wood to hold it out so you can get on a creeper and work at removing what is left of the bolt. You may have to drill it out and run a tap up in the nut that is welded in the rocker panel. If the nut breaks out then you will have to weld a new nut in its place. To help you pop the fender down and over the bolt remove the bolts from the top of the fender and remove any shims that are under them. There is also a few bolts just inside the back part of the fender and in the door jam in front of the door, you will need to remove them too. Open the door and look inside the door jam toward the fender and you will see them. You will also have to remove the inner fender bolts. There is one about 8 inches in behind the wheel that screws up into the fire wall or you could just remove the ones that are just under the fender well lip. This should give you enough leeway to pull the fender out and down to get at the problem bolt. But if it was me I would just remove all of the bolts and take the whole fender off. Once you get the rest of them out along with all of the shims the fender will drop down and come off the bolt. You must be somewhat young. I love it when I hear about the younger guys fighting what I fought for living many many years ago. The fenders on those old GM cars bolted on a lot different then the unitized body cars that are in production today. One more note: When you put the bolts back in be sure and put some sort of never seize compound on them. Have fun and good luck.
Old 11-08-2010, 07:43 PM
87fubar's Avatar
i have the fender off now had to get to other stuff to fix an was hopin for some idea's for getin the bolt out
was thinkin drillin it out then weld washer to nut an weld it in were the hole is
Old 11-08-2010, 08:03 PM
Yep when the nut was bad that is exactly the way that I fixed them. Just take a die grinder and hog everything out. Weld a nut onto a washer and the weld the washer up into the hole with the nut side up, works great and last a long time. After you weld the nut on the washer make sure you can still screw the bolt into it. You may have to clean the threads with a tap to be sure.
broken bolt / thermostat housing RodFather Engine 17 01-24-2010 09:58 AM
aligning hood gto_ron Body - Exterior 8 03-25-2009 06:22 PM
Body alignment 1949HevyChevy Body - Exterior 2 11-12-2008 04:49 AM
adjusting door fender gaps on 60s ford? 62galaxiguy Body - Exterior 1 06-13-2008 07:43 AM
"Bowed" deck lid cruzinTLT Body - Exterior 3 03-04-2005 09:24 PM
