broken metal brakeline headache - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2010, 08:19 PM
MosinNagant's Avatar
Chevy Cheetah
hello everybody,
im having a bad situation with my 68' chevy truck the front driver side rubber brakeline was torn, and upon removing it my friend broke the metal line.
now im having a terrible time removing it, any ideas [tricks]on how to remove it will help.should i replace the entire set of tubes seeing that they won't budgeand just stripping?
Old 05-05-2010, 09:29 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
I wouldn't fool around with the old lines, you'll
be far ahead using new lines. also with the rubber hoses,
I wouldn't use them either, I would use the barded brake hose,
do you still have drum brakes on this truck?
Rich
http://www.russellperformance.com/mc...es_truck.shtml
Old 05-05-2010, 09:49 PM
brake line fittings
i use a small vise grip the slight squashing of the ferrel nut usually loosen them. this methode has worked 100%for me. just practice with how much to flatten the nut. cliff
"Basics of Basics" Molding repair / metal finishing MARTINSR Body - Exterior 6 07-09-2009 09:47 AM
sheet metal work robs ss Body - Exterior 2 11-22-2006 04:19 AM
metal finishing pictures sevt_chevelle Body - Exterior 2 11-14-2006 06:09 PM
Etch priming over metal 2 metal dave4943 Body - Exterior 1 06-17-2006 01:51 AM
Fan hit upper rad. hose!! mustangdude947 Engine 14 08-19-2004 03:52 PM
