Broken Oil Dipstick - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-14-2005, 11:15 PM
74_Chevy's Avatar
Lead Foot Hotrodder
Broken Oil Dipstick
I was installing my headers and I cracked my oil dipstick somehow today when I was driving I smelt oil burning and looked under my hood it's leaking oil out the dipstick when I looked at it I ended up breaking it off totally. Can you tell me how to replace it. It broke right the base close to the block. Do u unscrew it ? Plz let me know
Old 08-14-2005, 11:32 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
You should just be able to pull it out. Can you grab whats left with a pair of needle nosed pliers?
Old 08-15-2005, 12:15 AM
74_Chevy's Avatar
Lead Foot Hotrodder
yeah just didn't know if there was a certain way to do it I can do it tomorrow then
Old 08-15-2005, 12:26 AM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
is it a factory piece or one of those cheap chrome Mr. Gasket brand dip sticks?
If it's factory be careful removing it, if its a cheap one then be really careful. If you break it off clean with the block your going to cause yourself some trouble.
Old 08-15-2005, 12:52 AM
73oldsman's Avatar
I had the same situation years ago and got it out with an old easy out. The one I broke off was clean to the block, with no way to grab it. Good Luck!
Old 08-15-2005, 11:00 AM
GoneNova/406's Avatar
a long screw might work.it doesn't have to grab much unless its been in there so long that its welded its self with rust.you might want to shoot some wd-40 on it a day in adv.
Old 08-15-2005, 08:52 PM
Did you break the tube off? If so, get a bolt that will screw into the part of the tube that's in the block. Screw it in (it will jam, but that's what you want) and then take an open-end wrench that will barely slip over the shaft & tap the bolt head upward. Tap the wrench with a hammer or something if you need to. The broken tube should come out with the bolt.
Old 08-15-2005, 11:19 PM
74_Chevy's Avatar
Lead Foot Hotrodder
yes guys broke right at the block I thought I could get it but I can't I'll try the screw tomorrow after work hopfully I get it. Its the standard one that came with the block and it on the DRIVERS SIDE. Do u guys now where I can get a new one autozone only had the long ones. I'm assuming for the pass side.
Old 08-16-2005, 10:53 AM
71 c-10's Avatar
just a kid and his truck
we put a 350 in a 49 p/u at my work and it had the same problem you do. one of the techs had a little taper that fit into the hole and it had thread on it so it could grab and it was attacted to a small slide hammar, came right out.
Old 08-16-2005, 11:04 AM
Big Block Z28
You can get a new one form Summit or any other mail order house.
Old 08-16-2005, 07:59 PM
74_Chevy's Avatar
Lead Foot Hotrodder
picked up one at the junk yard off another truck 2 bucks just like the one I broke now if I can just get the other out I'll be in business. Gonna try the bolt thing it's been stormin bad here and i work long hrs we'll see when I get to it maybe tomorrow not sure
Old 08-18-2005, 01:51 AM
74_Chevy's Avatar
Lead Foot Hotrodder
tried the bolt thing no go i spent like 2+ hrs on it I finally took a smaller one and shoved it in the one that broke it works fine no leaks and the dipstick is in the right place
M.S. requested joke thread hotrodit Off-Topic 187 08-31-2014 07:14 AM
oil change- step by step instructions for women and men Fireball Hotrodders' Lounge 38 08-30-2008 08:39 AM
Fan hit upper rad. hose!! mustangdude947 Engine 14 08-19-2004 04:52 PM
Should I change my oil? 48Man Engine 2 01-29-2003 08:28 AM
broken oil dipstick tube guilty1 Engine 10 01-16-2003 04:17 PM
