broken oil dipstick tube - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-06-2013, 10:45 AM
how do i remove a broken dipstick tube from a 327 engine block
Old 06-06-2013, 11:51 AM
Banned
where is it broken? in the block or can you grab some of it?
Old 06-06-2013, 02:25 PM
poncho62's Avatar
Wiki Edits: 5
Easy out might grab it
Old 06-06-2013, 03:56 PM
Get a large sheet metal screw that fits the remaining tube tightly. Sometimes you can simply screw it in and use a large screwdriver to pry it loose or grab it with vice grips. I actually made a remover by welding that sheet metal screw to a bolt that fit in my slide hammer. Weld them head-to-head. I've pulled several broken dipstick tubes this way.
Oil out dipstick tube Toyota350 Engine 3 07-13-2011 12:15 PM
Broken Dipstick Tube Removal smokey626 Engine 9 02-27-2009 01:50 AM
Broken Oil Dipstick 74_Chevy Engine 11 08-18-2005 12:51 AM
oil coming up through dipstick tube stoneyone2001 Engine 10 04-12-2004 09:10 PM
broken oil dipstick tube guilty1 Engine 10 01-16-2003 03:17 PM
