Broken Oil Pump Shaft - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-15-2008, 01:25 PM
Stromberg 97s's Avatar
Help..I posted some pictures in the gallery of my broken oil pump shaft..The pump is modified 340 mopor by Hemi Hot Heads to fit my 241 Dodge Hemi..I have only 200 miles on the engine and noticed 0 oil pressure..What I don't understand is why the shaft broke before the pin that hold the rotor on the shaft or the pin that hold the gear on the intermediate shaft to goes to the oil pump shaft..the pictures are high resolution so you see..Any feed back would be appreciated..
Thanks
Duane..
Old 03-15-2008, 01:33 PM
New Member
Bad Metal?
Can be a number of reasons, most likely was a bad casting....
Was it a repro part (made in Taiwan?)
rico_bob
www.***********.com
Last edited by Jon; 03-15-2008 at 07:11 PM. Reason: Advertising. Please see: commercial posting guidelines.
400 Small Block oil problems bac6772 Engine 40 07-05-2007 12:49 PM
Oil pump drive shaft cdiedrick Engine 2 08-24-2005 06:17 PM
Which waterpump? Eagle1 Engine 5 08-06-2004 06:38 PM
distributor gear / oil pump rod issue?? bskaggs Engine 8 06-11-2004 08:02 PM
Should I change my oil? 48Man Engine 2 01-29-2003 07:28 AM
