broken stud
hey guys, i got a buddy that has a 98 mustang cobra 4.6 5 speed
his passenger side ex. manifold has a broken stud in ot where it meets the ex. pipe, he wants to ask the experts how to get it out, thanks in advance TURBO |
Spray it with a penetrant like P.B Blaster,spray all the others too if they are still attached.Drop the exhaust,allow it to sit overnight if you can.Then take vice grips and tighten down on the remaining stud and work it out. I f you are in a shop and ahve access to a oxy/aceteylene torch,heat the manifold flange around where the stud is,metal expands with heat,then use the vice grips to remove the stud. If not use P.B Blaster over WD-40,much better penetrant lube.
Any grinding or drilling you may do,WEAR SAFETY GLASSES. Especially if you do it on the car instead of removing the manifold.
