Broken tv cable end - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2013, 09:59 PM
Broken tv cable end
Broke the end of the tv cable (at the carb) and am wondering as to how to go about repairing it without buying a new cable. I understand that they have a replacement for this end but wonder how it is placed onto the cable? The little bead that is on the cable that holds this part on is either fused or stamped onto the cable. Does one cut the cable, remove the bead and then place the new piece on? How do you replace the bead? Is there another way that one can repair this end in another way?
Old 06-15-2013, 10:21 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
My opinion is that I wouldn't dream of repairing that cable ... I'd replace it.
I have just read too many stories of what happens if the adjustment isn't just perfect.
Old 06-15-2013, 11:05 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
there is a slip on replacement end. Depends on design you need to connect to carb linkage if this will work
Simply slip over cable, no cutting , as it clips to carb spud, it is alll held in place
The Following User Says Thank You to Crosley For This Useful Post:
27Tall T (06-16-2013)
Old 06-16-2013, 12:28 AM
replace these cables play an important part in overdrive transmission life!!!!!
The Following User Says Thank You to reevislong For This Useful Post:
Old 06-16-2013, 09:50 AM
Breakage of the plastic end fitting at the carb is very common. The repair end is designed to snap over the cable on the retainer bead. It takes about 30 seconds to install. Despite people who claim that the trans will burn up, fire will rain from the skies, and the world will end if you don't replace the entire cable, the reality is that this little repair piece works fine. I had one on a 200-4R TV cable for several years with no issues whatsoever. I'm guessing that the people who crap on them have never actually used one.
The Following User Says Thank You to joe_padavano For This Useful Post:
Old 06-16-2013, 12:25 PM
Banned
never seen one, got a link?
The Following User Says Thank You to gearheadslife For This Useful Post:
27Tall T (06-17-2013)
Old 06-16-2013, 02:16 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I think the brand is Tech Pak, TeckPak - Fitzall or how ever they spell it
Old 06-16-2013, 03:53 PM
Dorman Products P/N 41020.
Interestingly, Summit and a couple of other on-line site shows it as not available or our of stock. Not a good sign.
Old 06-17-2013, 02:55 AM
Never heard of one Guess I'm ignorant to such a thing, and yes fire will rain from the sky cuz i would be mad enough to bring hell on earth after burning up a trans for a $28 dollar cable!
The Following 2 Users Say Thank You to reevislong For This Useful Post:
27Tall T (06-17-2013), 66GMC (06-17-2013)
Old 06-17-2013, 04:39 AM
The repair end attaches to the carb the same as stock. You still need to adjust the cable properly after installing the end. If spending more money lets you sleep better, knock yourself out.
Old 06-17-2013, 03:41 PM
66GMC's Avatar
Good info on the repair clip, Joe / Crosley.
My (ex) son-in-law had snapped the plastic clip off of the TBI end, and went to GM for a whole new cable. (1989 C1500)
The Following User Says Thank You to 66GMC For This Useful Post:
Old 06-17-2013, 04:50 PM
Project89's Avatar
the cable on mine snapped right behind the plastic clip but i needed it to work while my r eplacement cable came in .
what i did was get a electrical crimp ring terminal that fit over the stud on the carb and crimped then soldered it to the cable. hooked it upto the carb stud and then used an e-clip to retain it in place.
after i just readjusted the cable and it worked fine till i got around to swaping out the entire cable for a new one
The Following User Says Thank You to Project89 For This Useful Post:
Old 06-17-2013, 08:43 PM
You're right Joe. Have been to Napa, Quest, O'Reilly and a few others and it seems that this part is now officially extinct. Not driving the car now and so I will have to replace the cable if I intend to go cruisin'. Thanks to all.
Old 06-17-2013, 09:40 PM
66GMC's Avatar
NAPA (Balkamp / OE Solutions) part # OES 665-2141.
Call your local store to check availabilty using this part number?
27Tall T (06-18-2013)
Old 06-18-2013, 02:00 AM
They also make aftermarket adjustable ones I beleive i seen them in summit. They work good for when for ex. you're doing a tpi swap with a 700r4 extra long cable, they don't make anything stock that long!
Broken detent cable on 350 turbo. eric32 Transmission - Rearend 2 08-29-2010 06:07 PM
Broken accelerator cable coinbandit Hotrodding Basics 2 11-29-2008 09:47 PM
broken gear tooth ? rear end fast68 Transmission - Rearend 3 09-02-2007 10:08 PM
Emergency brake cable end fix needed jprimo Suspension - Brakes - Steering 2 05-16-2005 12:16 AM
Throttle cable swap... how does the pedal end hook up? sizemoremk Engine 3 07-21-2003 01:54 PM
