If you wanted to measure the installed height, you'd use the figure you get and subtract the valve lift from it and compare that result to the spring's published max lift or coil bind point. If you don't know what those figures are (because you don't know what brand or part number of the springs you have), then the best bet is to measure the coil bind clearance- like you mentioned and I described earlier.
You would also measure the distance from the bottom of the retainer at its lowest point (where the locks are at, in the center of the retainer on the bottom) with the valve on the seat- to where the retainer contacts the valve guide boss. If the lift is more than THIS measurement, the damage could have occurred. If you find that there is enough clearance by whatever means you use, then you'd want to know what the spring pressure was. This is so you could see if the spring may have allowed the valve to float, causing the damage. Usually for valve float to cause such damage, the RPM would need to have been fairly high at some point. This could have started the valve to break, then later on you might have been at an idle when the valve finally gave out. More HERE, just remember that the total clearance between the coils is 0.060", NOT 0.060" between every coil, like they show. |
This diagram actually has the coil bind measurement correct.
>> http://www.chevytech.info/3c4o1.htmlRocker Geometry>> http://www.chevytech.info/3c3o1.html Shows how with 1.6 Rockers the Pushrod moves closer to rocker Stud>> http://www.chevytech.info/3c3o2.html Last edited by SSedan64; 03-07-2011 at 10:52 PM. |
The hydraulic lifter will compress, or "bleed down" from the spring pressure- you'd need to use a solid lifter adjusted to zero lash to use the method you're showing.
If the heads aren't modified and the springs are stock, that much lift isn't going to work- the valves will float- if coil bind or lack of retainer to guide boss clearance doesn't get them first. I'm surprised there isn't interference with the pushrods to the guide holes in the head- unless the holes have been opened up. |
So basically you're telling me i need to get new springs, retainers, and enlarge my pushrod holes in the heads to fix my problems? i really want to get a new set of heads, but i just don't have the money to do it right now and i don't see myself having it anytime in the near future so i need to fix this and drive it for at least a year like it is. I just don't want to have problems with it.
Well i've been doing some studying and it seems that you are correct. I can't say for sure that the retainers are contacting the guide boss though because being that it has the umbrella seals on it i would figure that it would have damaged the seals had they ever contacted? Also i don't see any sign of the pushrod hitting anywhere in the head. So basically i'm looking into springs at this point, i just have to figure out exactly what type of spring i need for my cam.
The retainers may be OK- unless you need a larger diameter spring or more installed height. Then possibly different retainers and/or locks would be needed to provide that extra diameter or installed height. Try to find a set of springs that are stock diameter, else you'd need to machine the spring pockets for bigger diameter springs. A set of $30 "Z-28/LT-1" springs may be an answer. These springs will work w/lifts up to 0.510" at a 1.7" (i.e. stock) installed height. They will fit the stock spring seat and will use the stock retainers. You still would need to verify the clearances. They have 120 lbs @ 1.7", 300 lbs. @ 1.250" and coil bind @ 1.160". |
hmm ok but if i was to re use the 1.6 rocks that would put me over the 5.10 lift on the exhaust side. I have a set of stock 1.5 rocker arms but they are factory with about a million miles on them probably so is there any other springs that would work with my stock retainers and the heads that would allow for that little bit more lift? or do i just need to get a new set of 1.5 rockers
ya i bought the set of 1.6 for like 80 bucks. i'm just trying to do that cheapest route possible because i am broke and i don't want to dump any money in these heads, but spendining 800 for a set of heads is completely out of the question right now.
that's kind of what i was wondering. what about the slot though. I've heard about problems with the slot on stock rockers with a high lift cam. When i bought the 1.6 i bought the "long slot" ones.
| (pics) broken valve spring, what to do. | slate84 | Engine | 28 | 05-20-2009 09:38 PM |
| Broken valve spring(s)...? | Bumpstick | Engine | 5 | 06-06-2005 07:33 AM |
| Broken valve spring??? | Miligav383 | Engine | 6 | 05-16-2004 09:40 PM |
| broken valve spring dampner | nastynova | Engine | 18 | 07-04-2003 09:28 PM |
