bronco 2 wires - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2003, 11:14 AM
New Member
Post bronco 2 wires
I have a connector that hangs down on the drivers side near the transfer case. It's 2 conductor and has light blue and light blue with black stripe wires but i cant figure out where they are supposed to go ... any ideas? thanks
Old 04-21-2003, 03:18 PM
4 Jaw Chuck's Avatar
Post
What doesn't work?
Outlawed tunes from outlawed pipes
Old 04-22-2003, 04:56 AM
New Member
Post
Im smart enough to figure that out. My problem is that the answer to that question is nothing...... nothing doesn't work. everything seems fine(except for a loss of power and bad gas milage). and i looked everywhere under the car and i cant figure out where this plug should go.
Old 04-22-2003, 04:58 AM
New Member
Post
also my abs light comes on a lot...but that seems more like a loose wire. sometimes its fine for days.. and some times it goes on and off
[ April 22, 2003: Message edited by: shotgunsean76 ]</p>
Old 04-22-2003, 05:15 AM
Pontiac Knowledge Base Editor
Post
I can double check the wire colors but I need to know what year motor and trans are in it. The wire colors change from year to year and auto to 5 speed.
Do the lights come on when you put it into 4 wheel drive? if so it might be for the seat belt warning buzzer. The wires run under the cab and into the floor behind the drivers seat. And the cruise control wires plug into the t-case at the speedo cable. The back up light wires go ontop of the trans near the shifter also. And the neutral safty switch is kinda hidden as well.
Old 04-22-2003, 06:58 AM
New Member
Post
the lights do come on in 4 wheel drive. The motor and tranny are both 1987 stock. It is an automatic though. After you said that though ... I wonder if its a sensor for manual trannys. I'm going to double check my reverse lights but i think they work.
Old 04-24-2003, 02:38 PM
New Member
Post
it wasnt the revers lights...the connection for the seat belt is hooked in and the nuetral saftey works fine. It has to be for the manual tranny
[ April 24, 2003: Message edited by: shotgunsean76 ]</p>
Old 04-24-2003, 04:23 PM
Post
Likely it's a wire for something that was never installed in your truck, the factory puts full harnesses in even if the truck doesn't have all the accessories. Have you tried a voltmeter to see if it is getting power?
Old 04-25-2003, 04:15 AM
New Member
Post
I checked that also. It is an 87 xlt with every option that was available. Right down to the inflate seats, cruise control, 4x4, power windows and locks
