bronco aod transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2007, 07:49 PM
I have a full size bronco with 302 engine and an aod trans. When I accelerate it shifts smoothly into overdrive at about 55. If I let out on the throttle it drops hard into overdrive at about 45. Also at 65 I can feel the transmission shudder. Is my overdrive band worn out?
Old 11-27-2007, 09:00 PM
airworld2's Avatar
bronco
hard 3-4 shift can be from too high line pressure , tv pressure out of adjustment. can also have worn check ball in valve body.shudder is more consistent with an engine miss, no converter clutch in and aod converter pre 93 unit.....you might check u joints
airworld2
Transmission Information. M&M CUSTOM Transmission - Rearend 1 08-24-2004 03:15 PM
Ford AOD Transmission..... PonchoTA79400 Transmission - Rearend 1 02-03-2004 04:38 PM
'86 Bronco II manual for transmission Jaz Transmission - Rearend 0 09-05-2003 01:02 PM
AOD transmission swap Doug Renton Transmission - Rearend 1 10-07-2002 03:23 AM
Drive Shaft AOD Transmission melbishop Transmission - Rearend 1 04-03-2002 08:01 AM
