bronco2 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-02-2007, 08:59 PM
bronco2
I have a 2000 Ranger 4.0l that i was hopeing to put into my 86 Bronco2. Can it be done, and ballpark how much will it cost?
Old 01-02-2007, 09:09 PM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
yes it can be done. The more common swap is a 5.0 (302). I have a friend who is planning a 4.0 SOHC swap (2nd gen explorer) into an 84 Bronco II.
If you have the complete donor vehicle, you should not need many additional parts when you do the swap. I assume you will be doing the swap yourself, so the cost won't be bad.
Now if you are talking a shop...that's a whole different ballgame. There is a ton of wiring, sensors, the computer and everything else that has to be moved. I would bet that the drive shaft (s) would need to be custom made too.
What transmission do you plan to use? That would govern the transmission mounts and shifting linkage.
If you get into the swap and need specific help, contact the guys at ranger resource. ranger resource. net
Old 01-02-2007, 09:12 PM
redlightning's Avatar
http://www.therangerstation.com/tech...onversion.html
http://www.therangerstation.com/tech...onversion2.htm
http://www.therangerstation.com/tech_library/index.htm
Welcome to the forum.The links above has some info.
HELP!! Ford Bronco2 Automatic IAMCANADIAN Transmission - Rearend 6 03-10-2003 08:09 PM
87' Bronco2 4x4 won't work IAMCANADIAN Transmission - Rearend 1 02-06-2003 12:44 PM
CANT GET BRONCO2 STARTED !!!!!!! rosi777 Engine 4 01-12-2003 09:53 AM
BRONCO2 MORE INFO !!! rosi777 Electrical 2 01-12-2003 09:03 AM
1988 BRONCO2 4 WHEEL DRIVE rosi777 Electrical 0 01-12-2003 08:47 AM
