Bronze colored rod ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-06-2013, 03:16 PM
I had my engine in the machine shop and had new pistons put on the rods. the rods were all the same color when they went in but when they came back # 7 came back with the wrist pin end a bronze color. Im concerned about the possibility of the rod having ben weakened by the obvious over heating of the rod. Can someone tell me if I should be concerned about this issue ?
ID:	75444   Click image for larger version
ID:	75445   Click image for larger version
Old 07-06-2013, 03:25 PM
techinspector1's Avatar
Wiki Edits: 326
The machinist uses a special rod heater to heat the pin end of the rod to ease intalling the pin. Nothing to be concerned about.
The Following User Says Thank You to techinspector1 For This Useful Post:
rndyhd (07-06-2013)
Old 07-06-2013, 03:31 PM
BOBCRMAN@aol.com's Avatar
The bronze color is from a factory procedure to tighten up the pin fit. The rod is plated to make the pin hole smaller, resized and then used.
The Following User Says Thank You to BOBCRMAN@aol.com For This Useful Post:
rndyhd (07-06-2013)
Old 07-06-2013, 04:07 PM
The straw color indicates the rods were heated to about 600* F in a rod heater which is the approved controlled method and correct temperture. I would not worry about those rods. A acetylene torch or some other uncontrollable method of heating a rod should not be used to install pins. That is the main reason GM recommends press fitting the pins in their PM rods.
The Following User Says Thank You to MouseFink For This Useful Post:
rndyhd (07-06-2013)
rod discolored
Can I replace Bronze Valve Guides myself? Dougie Engine 8 01-20-2011 03:50 PM
MIG or Bronze..??? Augusto Body - Exterior 4 03-05-2010 12:49 PM
Fuel Pump Push Rod With Bronze Tip & Roller Billet Cam leejoy Engine 3 01-31-2008 03:53 AM
Bronze guide liners NorthStar Engine 12 03-20-2006 05:34 PM
Bronze Dist Gear markn Engine 3 08-01-2004 08:55 PM
