Brow in door skin - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-11-2013, 05:18 PM
Brow in door skin
My coworker has a newer Saab, and she hit the door somehow and now it has a brow with a low spot right above or underneath, I don't recall. She asked me if I could do something about it and said I prob could, but I wanted to check with the powers that be here to check my methods before laying a hand on the door.
It doesn't need to be a perfect repair, just make it so it's not so obvious. My idea was to use my slapper to gently tap down the brow while working the low spot out with a dolly while I tap. I was going to put some tape on the slapper to avoid marring the finish. I repaired the brows in my Mustang roof this way with good results, but we all know that wasn't a finished surface.
I was also wondering if I should warm the area on the door so the paint isn't brittle. I told her I won't do it if it looks like things will only be made worse. This is just supposed to be a bump and done thing. With the car that is, not her.
Old 01-11-2013, 10:11 PM
You have the right idea, no if's ands or buts, perfect. Heating the paint, never did it but the PDR guys do that so it must be a good idea.
Old 01-12-2013, 05:53 AM
Faith - Respect - Trust
One question I would have before you try and straighten things out is, is there any filler at the point that you are trying to straighten? Metal has memory, so straightening metal is a lot easier than trying to straighten a spot with filler in it...filler has no memory.
Old 01-12-2013, 06:44 AM
This car is only 4 or 5 years old and never been in any accidents, so there shouldn't be any filler on the door.
Old 01-12-2013, 06:56 AM
OK, it was just a thought and I didn't want you to start a repair that couldn't have a respectable out come. In 2003, I had a neighbor that just bought a 1 year old Hyundai Accent...real low miles, under 5K...He had a little ding in the fender and asked if I could get it out....I tried...but...there was filler right beside the spot that I tried to straighten...so like I said, just a thought.
Ray
Old 01-12-2013, 03:39 PM
deadbodyman's Avatar
Wiki Edits: 11
Mabee pulling the low spot with a suction cup while slapping the high spot
71 nova door skin crusherdbuzz Body - Exterior 1 02-23-2012 03:20 PM
Should I cut my Inner door skin off? Riot Racing Body - Exterior 6 06-03-2010 08:16 PM
Door Skin BLOWN 1100 Body - Exterior 4 05-09-2007 09:04 AM
Door Skin nova69 Body - Exterior 5 10-18-2005 05:58 PM
Door Skin Replacement bmech211 Body - Exterior 5 11-25-2003 05:25 PM
