brush on paint for new floor pan - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-18-2011, 05:01 PM
I have all new sheet metal floors, firewall and rear trunk area in my Austin a40.I am trying to figure what paint is going to work best,I plan on using a brush on paint.And I dont want ot use por 15 I have been looking at Summit chassis paint which is a 2 part epoxy that can be brushed on bare metal.
Anyone have any suggestions on what paint and what seam sealer would work best.And should I seam seal before or after painting
Old 09-18-2011, 05:12 PM
poncho62's Avatar
Wiki Edits: 5
Not sure about the sealer, but I would use an epoxy primer first before any paint.
Old 09-19-2011, 09:04 AM
Old Fool's Avatar
SPI epoxy is brushable, rollable, sprayable.
Old 09-19-2011, 06:51 PM
Why don't you want to use POR 15?
If you clean the metal and prep the surface properly POR 15 goes on smooth as glass even with a brush. Just scuff the surface and paint with your choice of interior color.
I am using window flashing (the kind you can get at Lowes/ home depot) it's an 1/8th inch thick and has a metal backing. It's much cheaper and goes on great. If you put the coatings on it doesn't matter what color the paint is and your using on the floor only anyway. (Inside)
If you want to go on the outside I would still use POR 15 or you could use Master's Series.
If you don't want to use something so expensive then use Farm Implement paint at any paint store it's bullet proof.
Old 09-19-2011, 08:56 PM
.......And should I seam seal before or after painting
Definitely paint before seam sealing.
And I'd use some sort of epoxy on the floors since it's new clean metal.
Old 09-20-2011, 08:23 AM
Yep I ordered summet brand semi gloss epoxy chassis paint
Old 09-20-2011, 10:52 AM
Any paint is brushable.. It just might not look as good. Which is moot here.
Old 09-21-2011, 06:58 PM
spc78's Avatar
I used Eastwood's Rust Encapsulator, then seam sealed, then coated it all with Eastwood's Chassis Black. Looks very crisp and clean.
Best Shop Floor Paint DaSouthWon Garage - Tools 11 11-07-2012 09:41 AM
A Simple Brush Paint Job - Newbie Help Ben_Tech Hotrodding Basics 30 06-20-2011 09:03 AM
Quality Paint Brush???? djjc76 Body - Exterior 3 01-25-2006 11:34 AM
Thinning paint for brush on Bluepen Body - Exterior 3 04-08-2005 06:19 AM
where can I get brush on heat paint? HotRodF100 Hotrodders' Lounge 5 07-15-2004 09:15 PM
