Brushed Aluminum Look on Steel - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2006, 09:14 PM
Can chromed trim parts and or a chrome bumper be treated to look like a brushed aluminum look?
I thought I saw something on one of those 'chopper build off' shows where a guy put chrome parts into a big churning bath of little milky nugget things for a long time and got this look.
Any ideas on how to do it?
Thx.
Old 04-18-2006, 03:22 AM
Brushed aluminum is done with a process called "graining", which basically involves taking a belt sander that turns at a slow speed and applying it to the metal surface. This creates the parallel lines that give brushed aluminum its "brushed" look.
Places that do anodizing will usually also offer graining services. If you bring it somewhere, have them show you a test piece done with the same belt they will use on your piece. I have been surprised at how deep the scratches have been with new belts, and have often had them use old belts for my work.
The problem here is that if you do that to steel, it would look fine until it started rusting a day later. Because of this, you would have to send the part out to be nickle plated to prevent rusting. Make sure they don't polish it or all the graining will disappear.
There may be other ways to acheive this look on steel, but that's what I would do.
Thanks,
PeterM
Old 04-18-2006, 12:55 PM
This what your looking for ? I do this with a Norton sanding sponge ,med grit- wet . Remember to add alittle dish soap to the water makes it much easier. I have left pipes like this for months without rust but then again they are rarely out in the rain. U could clear with a semi or flat clear to seal the finish .
takes some time to do the heat shields and small parts. think u would have to do a bumber in steps then do your bumber length straight sandin at the end just to uniform it up.
Old 04-18-2006, 03:30 PM
Originally Posted by Springer
This what your looking for ? .....
yes, that's the look, although I can't see real close. ideally have the grain fine enough that you can't see lines. Maybe follow on with some rubbing compound?
thanks for the ideas, i'll fool around with em a bit.
Aluminum against steel WakBordr7387 General Rodding Tech 4 02-08-2006 11:26 AM
galvanic corrosion, aluminum on steel? rlackey Body - Exterior 22 05-20-2005 07:57 PM
steel -vs- aluminum flywheel fat50 Engine 12 01-04-2005 03:16 PM
Bonding Custom Aluminum Panels To Steel bmech211 Body - Exterior 2 12-16-2003 08:49 PM
aluminum to steel ghastly53buick Body - Exterior 6 10-13-2003 06:28 PM
