Brushed finish on stainless steel - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2012, 03:21 AM
thinwhiteduke's Avatar
Living In The Past
Hi , Does any one know the best method to get a 'brushed' finish on stainless steel?
Wire brush or sand paper? I dunno?
Any advice??
Thanks
Duke
Old 04-21-2012, 06:46 AM
BOBCRMAN@aol.com's Avatar
Sandpaper and WD-40.
Old 04-21-2012, 09:50 AM
deadbodyman's Avatar
Wiki Edits: 11
sandblaster,with a brushing /sweeping motion
Old 04-21-2012, 03:48 PM
Living In The Past
Thanks guys..
Duke
Old 04-22-2012, 05:48 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
To get a brushed finish on stainless depends what type of material you are starting with.
If for example you have a mill finish piece of s/s bar, you will need to grind the whole surface somehow because that piece of bar will have a very rough surface. Sanding discs in the largest grinder you have will help keep the surface flatter.
After grinding, use something called a flap wheel in a die grinder to take out the grinding marks.
Then go over that with some emery cloth and follow up with some scotchbrite pad and you'll have a nice brushed finish.
Old 04-23-2012, 04:25 PM
Living In The Past
It's flat plate that im using as an insert in a center colsole around the shift stick, with that "lazer film" peal off protective film. Underneath is super shiny finish that I want to make look like the finish of a s/s on a 69 camaro steering wheel
Probably like about 180 grit I guess, I don't think it needs grinding, any ideas!
Thanks,
Duke
Old 04-23-2012, 04:39 PM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
Nice material to start with. I would only use Scotchbrite on it then.
Old 04-23-2012, 05:54 PM
Living In The Past
Thanks mate, I'll start with that and see how it comes up..
Duke
Old 04-24-2012, 02:58 AM
4 Jaw Chuck's Avatar
The brown very coarse scotchbrite will give you the finish you desire in one step, lubricate with varsol or kerosene to help it cut...soap works too but then you have to wash it off.
— Han Solo
Old 04-24-2012, 12:01 PM
Go slow and brush in one direction only in nice even horizontal swipes; try to stay as straight as possible and take your time. It won't take long.
Old 04-24-2012, 04:21 PM
Living In The Past
Thanks guys, I know the stuff you mean.
I'll get a nice sharp new piece, do a dummy run on an off cut and I will keep it straight...
Duke
Stainless Steel Tubing 2003ZR800 General Rodding Tech 9 10-30-2007 07:23 PM
Welding Stainless Steel to Hot Rolled Steel? Rambo_The_Dog General Rodding Tech 11 05-07-2007 11:05 AM
Brushed Aluminum Look on Steel TheMonkey Body - Exterior 3 04-18-2006 04:30 PM
Stainless Steel Wirewheel freakyheadbanger Hotrodders' Lounge 5 01-12-2005 05:36 AM
stainless steel?? akm Body - Exterior 4 04-16-2004 11:46 PM
