Bubble flaring tool? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-02-2010, 02:40 AM
staleg's Avatar
Last journal entry: Hand brake
I already have a good, metric 45 degree flaring tool, but the Jaguar rear calipers need bubble flare brake lines.
I've heard that many make a kind of bubble flare by just performing the first of the two flaring operations on the 45 degree flaring tool and use the result of this as a bubble flare.
But to make this 100% (as brakes should be!) I might need a speciual bubble flare tool?
Old 05-02-2010, 03:05 AM
Panelman55's Avatar
Loving God living in the South
You should never try to cut corners on brakes!!! You can get the tool from HF, Sears, Snap-on etc. You pick which one you like best.
Old 05-02-2010, 07:41 AM
Wiki Edits: 31
you could buy bubble flare adaptor lines.. any auto parts store can get them, and there a few incles long.. 1 end is bubble, the other is flare. just couple them with your standard flare lines and you have brakes just as safe as any
Old 05-02-2010, 07:47 AM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
KD Tools #3482
Old 05-04-2010, 03:33 AM
staleg's Avatar
Thank you for your answers. Here is an update.
To make a bubble flare by using a double flare tool plus deleting the last operation is not cutting corners. Actually it say so in the users manual for my inverted flare tool. I discovered it when I read it once more.
The kit car / hot rod guys using Jaguar rear axles do it all the time, because the Jaguar rear brake calipers uses this flare type.
But buying hardlines with bubble flare in one end, cut the line to correct length and then make the last bubble flare myself is also a good idea, of course.
Tips for shop layouts and tool purchases. schnitz Garage - Tools 9 10-18-2010 11:19 PM
Flaring tool 57halfton Garage - Tools 4 12-21-2009 08:55 AM
45 degree flaring tool ratrod47 Garage - Tools 7 05-18-2009 09:50 PM
what tool to use for a bubble flare?? STATUTORY GRAPE Suspension - Brakes - Steering 4 05-09-2009 11:37 AM
blaster vacuum 71corvette Body - Exterior 6 12-23-2007 07:24 PM
