i don't have any pic's of my hitch i made for my bucket..
depending on the wt u want to tow.. i just towed a coke trailer.
i used (i don't recall the exact sizing of steel) 1 1/2" sq tubing/pipe for the cross member and welded to the frame rails. used another pc of 1 1/2" welded to the cross pc pointing down. then drill a hole for the hitch pin. the make up a 1" sq tube to slide into the down pc and welded a 1/2" thick flat bar to the insert so the ball would mount to it.. that was drilled also for the pin.. with the slider piece removed u would have to look under the car to see the hitch assy.. brace all welded area with angled pc's of flat bar.
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
