Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Bucking in gear at idle
Old 05-20-2007, 03:20 PM
steveyb4342 steveyb4342 is offline
On the learning curve.
About the vibration, ever think of having the tires rebalanced? My car did the same thing until I got the tires rebalanced. Could be a slightly shifted weight. Or all your weights might be on the inside only to make you rims look better etc. You cant do this I tryed and the guy at my local garage said that you have to put weight on the outside or they will always shake some. Compremise looks for no shake?
As for the bucking, my old car did that lol. I found out later it was a crack in the vaccum hose on the bottom side {barely noticeable}. Hope this helps!
PS: Thanks for trying to help with my balencer issue, still not solved penetrating oil is doing its thing as we speak.
