Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Bucking and jerking not running right
  #33 (permalink)
Old 03-05-2013, 06:49 PM
LATECH's Avatar
LATECH LATECH is offline
Originally Posted by tommyboy8072002 View Post
Hi Guys just wanted to let you all know. That my truck is still running like crap. But it did bring up 4 codes. But nothing for a miss fire. I did notice that I am going on my 3rd set of plug wires. Some reason 6 and 8 burns them up melts them. Not sure what causes that but anyways.
Here are the codes.
p102.
P113.
P137.
P1406.
P0102 is a MAF sensor circuit/range problem. Could be the fuse (ECM 1 I think) The wiring harness could also be the problem.Check for 12 V + at the sensor.
P0113 is intake air temp sensor circuit low.
Both of those could be caused by having them unplugged with the key on.
P113 is bank 1 sensor 2 (bank 1 downstream O2) circuit low voltage
P1406 is EGR circuit trouble of some kind.
Fact is stranger than Fiction
