Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Bucking and jerking not running right
  #47 (permalink)
Old 03-09-2013, 08:12 AM
1Gary's Avatar
1Gary 1Gary is offline
Last journal entry: 383 dyno sym
When you clean the EGR (a dentist pick works good for that)get a screened replacement gasket from the help section at your local auto parts store.I will prevent carbon build-up from getting in there again.No grounds codes aren't in there,so it is reasonable broken ground would cause this.Keep in mind that first code is normally causing the others.So after fixing the ground issue,be sure to clear all the the codes.
