Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Bucking and jerking not running right
  #62 (permalink)
Old 03-10-2013, 03:53 PM
1Gary's Avatar
1Gary 1Gary is offline
Last journal entry: 383 dyno sym
Originally Posted by tommyboy8072002 View Post
What is a VSS?
Vehicle Speed Sensor.Controls shift points or shift light with stick shifts,dash control,in part also controls fuel curve and spark advance along with crank sensors.Because it is a replacement trans,the last touch theory might come into play.
A easy way to detect a clogged cat is to pull the upstream O2 and run it like that re-leaving the back pressure.If that resolves the issue then the cat is clogged.
