Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Bucking and jerking not running right
  #73 (permalink)
Old 03-19-2013, 09:04 PM
tommyboy8072002 tommyboy8072002 is offline
Thanks LA TECH. I will check the plugs and also see if I know someone that has a scanner. I have been driving the truck for awhile now. And still hasn't brought up a code. I did forget to plug in my Wiring for reverse lights at the very top of the transmission. But I don't know if that has something to do with it or not. Anyways I am going to drop down the transmission a little bit and plug it in. I am also going to look for grounds while I do that. Hey LATECH do you know what the ohms suppose to be on the EGR valve and on the map sensor..?
Thanks again
