Bucking and jerking not running right - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 03-08-2013, 09:48 PM
Ok thanks. I will try that first.
  #47 (permalink)
Old 03-09-2013, 09:12 AM
1Gary's Avatar
Last journal entry: 383 dyno sym
When you clean the EGR (a dentist pick works good for that)get a screened replacement gasket from the help section at your local auto parts store.I will prevent carbon build-up from getting in there again.No grounds codes aren't in there,so it is reasonable broken ground would cause this.Keep in mind that first code is normally causing the others.So after fixing the ground issue,be sure to clear all the the codes.
  #48 (permalink)
Old 03-09-2013, 12:10 PM
well I ran new ground wires on both sides. Little bit of difference. But not much. Egr looked good cleaned it anyway. still not running the way it should I checked so see if I have any wires in the bell housing Not a thing. You Guys think that the cats would be the issue. Would that make the tac jump when its idealing
  #49 (permalink)
Old 03-09-2013, 12:57 PM
Bucking
Not sure about the cats...was it running fine when the trans went out?
  #50 (permalink)
Old 03-09-2013, 01:00 PM
LATECH's Avatar
Originally Posted by tommyboy8072002 View Post
Ok 1406 is a Egr valve pintle position circuit. Will this cause pinging? I Also found a bad Ground wire. but I don't know if that would cause this truck to run like junk.
You really need to adress the P0102 and P0113 first, unless you generated the codes by having the MAF unplugged.
It will not run well with a defective MAF or a MAF that has no power to it.
Fact is stranger than Fiction
  #51 (permalink)
Old 03-09-2013, 01:27 PM
bucking
Maybe unplug the negative cable at the battery to clear the codes, then see if they come up again when you start it up . If they do, I'd recommend pulling the MAF and cleaning it with a sensor safe cleaner...they have a cleaner specifically for MAF sensors at any auto parts store. See if that helps
  #52 (permalink)
Old 03-09-2013, 01:56 PM
LATECH's Avatar
P0102 is actually a Circuit problem. Cleaning the MAF...although a good Idea wont fix it.
I have seen wiring problems as a broken connector, blown fuse and such cause the issue. It will also affect the transmission shift points and throttle pressure as it is controlled by readings from MAF and engine rpm/load and throttle position.
Also , unhooking the battery wont clear codes on OBD 2, it will clear the radio memory.
  #53 (permalink)
Old 03-09-2013, 02:02 PM
bucking
Latech, so you believe it is either a bad wire, a short or a bad connector? I've run into that in the past. I just questioned the MAF because I understood it was running fine when parked 4-5 months ago due to trans problems. You are probably right though...these modern electrical issues are not my forte.
  #54 (permalink)
Old 03-09-2013, 02:52 PM
LATECH's Avatar
That is what the P0102 is refering to...a circuit problem.
Certainly is an avenue to pursue first.Blown fuse, broken wire( B+ pink to MAF I have seen several times) , Defective MAF.
Cleaning the MAF is allways a good idea. Contamination will register a lean reading.
As long as the code is bonafide and not accidentally induce by technician, that would be the place to start.
  #55 (permalink)
Old 03-09-2013, 03:55 PM
1Gary's Avatar
A VSS would effect it all.Common to see the speedo doing stupid things when the VSS isn't working correctly.
  #56 (permalink)
Old 03-09-2013, 05:22 PM
LATECH's Avatar
The engine performance wont be affected by a Defective VSS. The trans on the other hand....
The speedo can jump around on that particualer vehicle while the thing is in PARK no less. Usually a cluster problem, or a ground problem, mostly the cluster at least that I have seen.
  #57 (permalink)
Old 03-09-2013, 08:44 PM
Thanks Everyone for trying to help me with this truck. When I pulled the transmission out to have it rebuilt I did notice all of the bolts on the bell housing didn't have any studs on them. I don't know if its because its a 5 speed manual transmission if that is why or not. my obd2 did clear the codes because I have a code reader. I ran 8 gage wire from the frame to each head made a difference. Not popping anymore. And its charging the battery. Before it would always discharge. But still running a little rough. But not like it was. I will drive the truck and see if the codes come back. When I unplugged the MAF sensor It quite. Once I plugged it back in it stays running. How do you clean the MAF. I will check the wiring with my test light or my ohms meter. let you all know what I come up with. Also check Fuses. Yes when I parked it. It ran fine.
Thanks
Tommy
  #58 (permalink)
Old 03-09-2013, 08:48 PM
What is a VSS?
  #59 (permalink)
Old 03-09-2013, 08:57 PM
wait sorry I didn't Unplug the MaF. I was Thinking the map sensor. I will check MAF sorry Guys.
  #60 (permalink)
Old 03-10-2013, 03:20 PM
bucking
MAF sensor cleaning is easy. Unplug it, remove it, use a MAF spray cleaner to the inside of it...you should be able to see a small screen inside it, just spray it down good. Any dirt or debri on that little wire in there will cause it to read incorrectly. Just the spray, dont try to wipe it off or use a brush to clean it. Bolt it all back together and see if you have improvement.
« Hi, ya'll | 350 »
bucking while cruising. stroker444 Engine 14 05-31-2010 12:35 PM
jerking drivetrain or rearend slipping??? 89camaross Transmission - Rearend 1 09-20-2008 11:08 PM
Bucking in gear at idle Bryan59EC Engine 7 05-21-2007 07:43 AM
hard steering and jerking BadAss_Beaver Suspension - Brakes - Steering 5 11-04-2004 12:20 PM
bucking at 2100 Ktaves1971 Engine 2 06-07-2004 02:27 PM
