Bucking and jerking not running right - Page 6 - Hot Rod Forum : Hotrodders Bulletin Board
  #76 (permalink)
Old 03-20-2013, 06:08 PM
LATECH's Avatar
I dont have values for the EGR. You can however, if you suspect the EGR , would be to cut a pop can open and make a blocker plate , for the EGR. Shape it like the egr gasket and slip it inbetween the intake and the EGR to block any flow or leakage. Super simple.
I am with bogie, my thoughts are problems with the injectors. Months of setting with todays quality fuels in them...LOL.
Probably corroded to death
Fact is stranger than Fiction
  #77 (permalink)
Old 03-20-2013, 06:43 PM
Thanks Guys. I will check it out and let you know what I find.
  #78 (permalink)
Old 03-20-2013, 07:44 PM
I just uploaded the pic of my plugs. Its in my profile. I hope you all can see them.
  #79 (permalink)
Old 03-21-2013, 06:13 PM
I was just wondering what you all thought of my spark plugs. Let me know what you all think.
  #80 (permalink)
Old 03-21-2013, 06:15 PM
You link won't load on my machine.
Bogie
  #81 (permalink)
LATECH's Avatar
# 3 looks excessivley rich , 4 and six look pretty good, the rest all look somewhat rich.Looks like a fuel imbalance problem.
I would be looking real hard at the injectors.
  #82 (permalink)
Old 03-21-2013, 06:43 PM
Hey La Tech Do you think a ground wire would cause that? Sorry about that BOGIE IM not sure how to post a pic on here .
  #83 (permalink)
Old 03-21-2013, 07:15 PM
You have to be a bit careful when reading plugs, fouled plugs can be too much fuel, oil, too cold a heat range, missfiring, leaking valves, wiped out cam lobes.
The only thing the crud tells you is one or more of those things are not working right. When you get some messed up and others not it's a pretty (especially if this is 180 degree intake and the fouling is not linked to one plane or the other) good indicator that the ignition is messing up but this ain't proof positive. On the other hand if the fouling tends to be common on cylinders feeding from one of the two intake planes, it raises the odds that fueling isn't consistent on one side of the carb/TBI injectors.
Bogie
  #84 (permalink)
Old 03-21-2013, 07:25 PM
LATECH's Avatar
Given that he tuned it up and still has the same issue , I am leaning to the only thing left here.The spider (injectors) are showing their age.
Number 3 plug is obviously fuel as it is Black.
It could be an ignition problem....but he allready changed all that and has the same problem.
IIRC he said he allready performed a compression test.
  #85 (permalink)
Old 03-21-2013, 08:28 PM
Yes I did a compression test . I can bump the key and it starts right up . I started pulling things apart to get to the injectors. I found a black ground wire coming out of the wiring harness. I will hook it up tomorrow and let you all know.
  #86 (permalink)
Old 03-21-2013, 09:39 PM
fixed the ground wire. Runs better still popping. I am still going to spend the extra money and buy new injectors, Plugs ,wires, rotor and cap
  #87 (permalink)
Old 03-21-2013, 09:50 PM
Bogie here is what the plugs look like.
  #88 (permalink)
Old 03-22-2013, 10:38 AM
Everybody but number 3 looks pretty OK, either the plug doesn't fire, bad ignition wire, bad cap, that injector or check valve is dribbling, defective spark plug, if this has a flat tappet cam I'd suspect a wiped lobe/lifter, bad guide letting a lot of oil down the stem, a valve that leaks past the seat.
Before I spent hard cash, I run a compression check. While I strongly would suspect the problem is with the injection for that cylinder, I'd stll run through the cheap and easy inspections first, I hate spending big bucks on parts only to find it was something else.
Bogie
  #89 (permalink)
Old 03-22-2013, 08:35 PM
Thanks Bogie. I will do another compression test. And check and see if its getting spark in #3 cylinder. I am not Shure what kind of cam is in this but I will check it out Along with cap, rotor, plug wire. I will see if the part store sells the thing to check the fuel presser
Tommy
  #90 (permalink)
Old 03-23-2013, 12:38 PM
ok I did a fuel test. I am getting 60 PSI with the key on with the key off I am getting about 58 to 59 . with the truck running I am getting 50 to 55 PSI. Let me know what you all think.
Tommy
« Hi, ya'll | 350 »
bucking while cruising. stroker444 Engine 14 05-31-2010 11:35 AM
jerking drivetrain or rearend slipping??? 89camaross Transmission - Rearend 1 09-20-2008 10:08 PM
Bucking in gear at idle Bryan59EC Engine 7 05-21-2007 06:43 AM
hard steering and jerking BadAss_Beaver Suspension - Brakes - Steering 5 11-04-2004 11:20 AM
bucking at 2100 Ktaves1971 Engine 2 06-07-2004 01:27 PM
