Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - bucking, stalling, but only on the highway
Old 07-02-2012, 02:14 PM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
I once had an old GMC Suburban that would do similar things and only when the outside temps were above 80 degrees.
After much greif, nashing of teeth and dis-assembly of most every component.. Three different new fuel pumps. It turned out to be the nylon "sock" on the fuel pick up, in the gas tank.
Someone, at a previous time, had poured something very strong into the fuel tank and the sock melted/shriveled up like an insect cacoon.. Amazing any fuel at all came thru it.. Look for a restriction in your fuel line..
