I once had an old GMC Suburban that would do similar things and only when the outside temps were above 80 degrees.
After much greif, nashing of teeth and dis-assembly of most every component.. Three different new fuel pumps. It turned out to be the nylon "sock" on the fuel pick up, in the gas tank. Someone, at a previous time, had poured something very strong into the fuel tank and the sock melted/shriveled up like an insect cacoon.. Amazing any fuel at all came thru it.. Look for a restriction in your fuel line.. |
What Bob said ^^, which includes all filters, if it has an in carb filter, check that too.
Midnight Sun Street Rod Association |
Ditto. You're losing fuel flow to the carb.
| Hesitation/Bucking problem | NEEDLEZ | Engine | 1 | 10-21-2011 08:24 PM |
| bucking at low rpm's | powerhunter | Engine | 2 | 07-09-2011 08:14 PM |
| bucking while cruising. | stroker444 | Engine | 14 | 05-31-2010 11:35 AM |
| Bucking in gear at idle | Bryan59EC | Engine | 7 | 05-21-2007 06:43 AM |
| bucking at 2100 | Ktaves1971 | Engine | 2 | 06-07-2004 01:27 PM |
