bucking and surging at around 2500-3000rpm - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-07-2003, 10:46 PM
Post bucking and surging at around 2500-3000rpm
I have a 406sbc with nothing but aftermarket parts. In my 84monte it runs high 11's in street trim. When i drive the car around town it has a tendency to buck and surge between 2500and 3000rpm when mainting cruise speed. The car has a 456 gear so that's where most my engine spends most of its time. My HEI dist. has vacuum advance and the canister is hooked up to ported vacuum on the side of the carb. I've heard that depending on what advance springs are in the dist. The ported vacuum could cause it to advance and retard the timing eraticly, also 2900 is right where my advance kicks in. Is this causing the surging or is it the tune on the carburetor. My carb is a 700cfm double pumper, it is jetted pig rich. I know the carburetor is way to small for my motor and when i had a friends 870cfm davinci on it it didn't surge or buck as bad. Any insight would be great.
Old 01-08-2003, 11:58 AM
1BAD80's Avatar
The Smell of Nitro in the morn
Last wiki edit: How to adjust valves Last photo:
Wiki Edits: 2
Post
change the power valve to a 3.5" in the carb.
[ January 08, 2003: Message edited by: 1BAD80 ]</p>
Luv the smell of NITRO in the morning.
Old 01-08-2003, 03:33 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Post
Its either to lean or to much timming.
