More info what are we dealing with,motor ,car,gears etc.
Cam,dist ,timing,static and total ,comp ratio,cylinder heads.
Msd HEI distributor with accel high output coil 14 initial 36 all in at 3k didnt build engine so i didnt check it myself, but person who did said its at 10:1 compression PBM Aluminum Heads, 220cc runners 2.02 and 1.60 valves 58cc chambers |
58 cc heads mean dished pistons to get the compression that low .What is cranking compression?
I would concentrate on the rear gear 3.42. when you changed to manual I would have maybe changed the gear . 220 runners too much for that mtr.
The reason I think you need more gear (lower) is because of the fact you mentioned all is fine above 2k. Your rear./ trans may be a good match to each other as you say, but maybe not that good of a match with your eng. I just think you may need additional r's at the lower speeds.. |
On acceleration and decelleration theres no jerking whatsoever, smooth as can be (except for the tires spinning! jk), its only when im doing part throttle the engine bucks. When i had to much vacuum advance it made it alot worse, but now im running low total mechanical so it shouldnt be that. Also in 4th gear which is direct gear, its the worst. It feels like im slamming on the brakes quickly then letting off. |
You Might Want To Check Your Power Valve. If The Diaphram Is Blown It Will Make Make You Pig Rich At Partial Throttle. Ask Me How I Know.
Change the power valve to a lower number, if it is blown it would be flooding out.
If expect a blown power valve, use this simple test. TEST: At idle turn your idle mixture screws (found on the side of the metering block) all the way in. If your engine dies the power valve is not blown.
Luv the smell of NITRO in the morning. |
Well it helped mine, what do you have to loose except the bucking.
It feels like the torque converter going in & out. I like a lower PV anyways, I run 3.5 in my carbs now.
| Effects of Axle ratio change on cruising RPM | Regal Beagle | Transmission - Rearend | 14 | 06-27-2008 01:17 AM |
| Front face of tire dismounted from wheel while cruising !!!!!!!! | Calderone | Hotrodding Basics | 7 | 06-05-2008 05:20 PM |
| SNEAK PEAK!!! 2009 Camaro Convertible Cruising on Woodward! Video first time ever! | powermelissa | Hotrodders' Lounge | 1 | 08-18-2007 09:19 PM |
| 1988 Camry cruising issues | ChevelleSS_LS6 | General Rodding Tech | 6 | 08-11-2007 06:41 AM |
| Almost cruising time. | HemmiGremmie | Hotrodders' Lounge | 5 | 06-10-2003 01:08 PM |
