Budget 350 build - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2007, 10:00 PM
Budget 350 build
I have gone through a few calculations to figure out a budget 350 build, I am not sure how close it would be because I cant find flow numbers for factory gm heads the numbers used were desktop dyno values for gm 882 heads. The heads are sort of an issue right now I have three set of gm castings 882s, 993s and 493s all are 1.94I 1.5E(I think the 493s have a 1.6E) the 993 need guides I would replace the valves/ springs on whatever ones I use I don't plan on increasing the valve size(minimal gain?) but I will do a mild port. I am not considering vortecs because I have an intake and the cost of the heads plus the machining/rebuilding to run the higher lift would put me into the cost range of a pair of Dart heads.
The block(010 with 010/020 cast) is a two bolt main 350, crank is polished stock cast, , the cam choice is comp cam http://www.compcams.com/Technical/Se...umber=12-246-3 or I have a 270 magnum. The pistons are Keith Black hypo dome pistons .100" that displace .5cc of cylinder volume they are a small dome.The pistons with a .017 thick head gasket and a stock deck height of .025" gives me a quench height of .042" with the piston compression height of 1.561(I think)? The rods are 5.7" (scat or eagle I beam) using that rod length my dynamic compression is 7.92 and my static is 9.77, cylinder pressure max is 185.5 @4000 rpm and the ve is 92.5% at 4500rpm with a 750 cfm carb(we have a quad, holley(3310) 750,650 and an elderbroc 600) and a high flow dual plane manifold(according to dd dyno) The engine use will be a strip steet car, auto 3000 - 3500 stall.
If the following numbers are good Id be happy with them and I know all the calcs should be based on actual measurements but I just need to get in the ballpark first? DD dyno spit out 413hp @5500 rpm and carried it to 6000, The torque was 440 max at 4000 rpm.... Does anyone se any major screwups or have suggestions, the heads I have are the cheapest alternative right now so one of the 3 will be used.
Old 02-24-2007, 03:51 PM
BOBCRMAN@aol.com's Avatar
The 882's are probably the best of the bunch. If not cracked. You can make a decent set of heads out of these, If you port match the intake side. carve all the rough/sharp edges out of the bowl. Smooth the short side radius of the exhaust and try to do all port work on the exhaust in the upper part of the port. Leave the floors alone. 1.94 Int. valves are fine but use some stainless 1.5 exhaust valves with a small back cut. You will have a budget screamer.
Old 02-24-2007, 04:32 PM
Look around and see if you can find a set of 441 heads, they are similar to the 882's but are a bit thicker and less prone to cracking-I've never seen one crack. The 882's are a little prone to cracking but they do produce some good power for a smogger head-especially if you open them up to 2.02 or 2.05, do a good bowl blend, raise the roof a little and narrow the port divider as mush as possible-they'll support 500hp if done right but it's a lot of work.
Old 02-24-2007, 04:38 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
http://www.chevyhiperformance.com/te...ench_database/
http://www.kendrick-auto.com/head_flow_figures.htm
http://users.erols.com/srweiss/tablehdc.htm
http://www.dw1977.cz28.com/photo2.html
Those are a couple sites with chevy head flows. I didn't take the time to see if they had all the flow numbers you need, but I know they have some.
Old 02-24-2007, 07:21 PM
Thanks for the info Ill take the 882s apart and have them checked out, I bought Vizard book on porting chevy heads and read the standard abrasive instruction along whatever else I can find on the web. I figure it take some time to port them and my time is limited but the budget for this one is more limited so Ill give it a shot. I am building a simple manometer to use for comparison hopefully it will work. Also please disregard my post on factory heads I posted it thinking I screwed up this one and it didnt post sorry about that....
Old 02-24-2007, 09:52 PM
Kgriff, check the compression height on the pistons you have, some of the rebuilder pistons end up .020 down in the hole on TDC and if that's the case you'll want to run a steel shim head gasket like original or have the block decked to zero and use a .040 composite head gasket. Try to keep the distance between the quench area of the head and the piston at .035 - .040"-this gives you the best burn.
Old 02-25-2007, 06:30 AM
Look at combo 54- 510HP http://www.ryanscarpage.50megs.com/combos7.html
Combo 38 uses a set of 882's with $1250 worth of head work-funny how they didn't increase the valve sizes from stock? What did $1250 buy?....
Old 02-25-2007, 09:44 AM
I looked through all of the combinations listed on the link none of the 882 head combinations made 400 hp which I find interesting because alot of the published flow data says they can. I did not input the 882 data in the dd dyno program it came with it. I have pulled the 882 heads and took a good look at them while I am no expert I am very skeptical of them supporting 400hp without extensive work. Compairing the three heads(actually 4 I have a set of 450 305s too) the 993s look alot more open/larger ports. In general none of them look very good. Right now I am leaning towards the 993s one combination on the link page that supported over 400hp
Combo 53.
Combos 53-54 come from pages 58-60 of the October 1990 Hot Rod Magazine. Back in 1990, these combos were two examples of the engines offered by American Speed. Both engines make some great power and torque.
Combo 53 uses rebuilt #993 GM heads with 2.02/1.60 in. valves. The camshaft is a healthy grind, with 234 of duration @ 0.050 in. of lift. This 355 cu. in. engine produces 421 HP and 438 ft-lbs of torque.
Displacement: 355 cu. in.
Carburetor: 750 Holley vacuum secondary
Heads: GM #993 castings, ported, with 2.02/1.60 in. valves and a 3-angle valve job
Intake: Edelbrock Victor Jr. and a 2 in. open-plenum spacer
Camshaft: Cam Dynamics 290, with 290 of duration, 234 of duration @ 0.050 in. lift, and 0.494 in. of lift
Headers: 1 7/8 in.
Pistons: Speed-Pro forged flat tops
Rods: stock
Crank: cast
Comp. Ratio: 9.0:1 to 10.0:1
MAX HP: 421 @ 5300
MAX Torque: 438 @ 4700
I am still going look at a few other combinations and price it out to see what the cheapest option will be.
Old 02-25-2007, 11:50 AM
Or just clean up all the old heads you have and list them as rebuildable sets on ebay, I've sold pairs of beadblasted 882 cores on ebay for as much as $178 in the past. Put your ebay sales profits together and buy a pair of aftermarket heads. If you consider what it costs to have guides put in and seats ground and new valves and springs you'd probably be dollars ahead.
Old 02-25-2007, 03:00 PM
The information I used was what came on dd dyno which was somewhat backed up by Car Craft http://www.carcraft.com/techarticles/116_cylinder_head_database/stock_iron_882_head.html since posting this and judging from most of the posts I sensed some do not believe the flow data. So I have researched it a bit further using books by Lingenfelter and Vizard. Vizard supplied Superflow Data for the 993s and Lingerfelter wrote that the 993s were better flowing than the 882s. Using this information inputted to dd dyno with my above combination listed above the best I could expect out off stock 993s is about 340hp the car craft info is either based on a magical stock 882 head of the info is flawed. Vizard also supplied Superflow data on a set of pocket ported 993s inputting this data that above combination on dd dyno would be slightly above 400 hp. I think in reality with me doing the porting its going to be a tough nut to crack, and it would be easier going aftermarket but its cold out the houses are far apart and I am not in that good of shape to deliver that many newspapers to buy a set of Brodix heads. I am going to search for a set of the 413 305 heads this week that does sound like a good option and I just picked up a 350 with flat tops in it.
finally finished chevy 350 build redneckrodder Engine 7 05-30-2011 06:03 PM
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
350 Build.. Im sure there are plenty of threads on this... but this is specific!! artillerystevens Engine 10 12-04-2006 09:34 PM
do it right the 1st time, strong 400 short block budget build, stock parts? Warrant Engine 9 12-04-2006 07:29 PM
350 Chevy build Streetmachine Engine 11 12-10-2001 04:31 PM
