budget 350 build ideas. need critics.. - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-11-2006, 11:36 AM
ok i`ve been researching, and here`s the combination i`ve come up with.
350 block, +.030, 9.010 deck, falt top 4 valve reliefspistons ,balanced rotation assembly, chrome moly rod bolts.
305 h.o. heads +.010 off heads just to ensure head gasket seating.
bowl work and light porting.
camshaft 214-224@.050 / advertised 280-290 / 443-465 lift/112 lobe cen.
.500 max lift springs
stamped roller tip rockers,
sfi approved liquid damper,
5 qrt oil pan
msd-6al ignition, 50,000volt hei tune up
weiand- XCELerator intake manifold, with removable plenum devider plate
edelbrock 500cfm,600cfm, or Road demon JR 525 or 625 cfm?
1 5/8 long tube headers, exhaust cutouts, and flomasters
Old 06-11-2006, 12:44 PM
budget 350 build
or not so much going with the 305 h.o. heads, but is it possible i could just shave the stock 350 heads how much should i shave off of the stock 350 heads to work with flat top 4vr pistons and get 9-1 or 9-5 c/r?? i was reading in some forums that by using flat tops with 58cc heads would average over 10-1 if not 11-1 , but by using special pistons would lower c/r. which would be my best bet?
Old 06-11-2006, 01:59 PM
cool rockin daddy's Avatar
Stop!
Why do you keep asking these questions and not paying attention to any answers? Why oh why would you want to use 305 heads?!
What 350 heads do you have now? What size combustion chambers do they have. 64 cc chambers will yield approximately 9.5:1 with flat tops.
Isn't that a single plane manifold you listed? No bottom end torque! You need a dual plane, especially in a truck!
How many more posts are you gonna put up here without doing any research on your own? How many more replies to your posts are you going to ignore? Nobody minds helping people on this board, but the person asking the questions needs to be serious about wanting input from the other board members!
Old 06-11-2006, 03:14 PM
firestone's Avatar
http://teamrfc.gospelcom.net
I had a 355 with flat top dual valve releif pistons and 64cc chambers, the builder said it was right at 9.98:1. With a set of 58cc heads on this combo, you would be around 10.5:1. That is not considering the fact that the heads have been milled. That motor will probably not run on anything under 100 octane.
Adam
Old 06-11-2006, 03:35 PM
budget 350 build
thak you for you input on the 305 heads, i guess it was kinda dumb to kinda want to interchange.All it would do is work against every aspect of this build.
when you say reserch as in what all the different components do and act with each other? example for it, a 50 state street legal camshaft will not work with a high rise manifold. it`ll cause hesitation and prolly won`t idle? things of that sort. or am i looking at an engine build at all the wrong directions?
Old 06-11-2006, 07:18 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
What he's saying is that you've essentially asked this same question before. Go back and read his advice from this thread you posted about a week ago and read his post again. He suggested you read some of the tech articles from a few magazines that are online. That's how you will begin to learn which parts work together to make power and which wont. You can throw just about any old SBC part on a 350 and make it run, but how well it performs is a different story.
I think you need to look at the GM Performance parts engines and pick one of them. They've done most of the choosing for you and you can get a good engine that makes good power and even has a warranty...
Old 06-11-2006, 07:39 PM
sorry about the confusion.
it`s just i had been told that an engine was built for mudracing using 305 heads with an edelbrock cam and it ran pretty good.so i tried to increase the cam and intake. i guess i have receive some big time Bull-shat advise, and suggestions. but i`ve already posted in one of the other threads about the 380hp, 420lbs torque build . i`m just gonna copy someone`s build or try anyhow.without closing the bank.
Old 06-11-2006, 08:29 PM
Blazin72's Avatar
Wiki Edits: 19
If you're on a budget and you choose to use factory heads then the only way to go is the Vortecs, they are far better than the 305 heads...
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 01:38 AM
help needed!!!! please read ... 350 build questions... 74chevyflat Engine 10 06-09-2006 10:42 PM
Need suggestions on 350 build pete379 Engine 3 06-14-2005 11:10 AM
350 tbi build up jackfrost51 Engine 3 02-01-2003 03:39 PM
350 rebuild ideas pls 56wagon Engine 6 03-04-2002 08:41 AM
