Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Budget 350 Build Question....
Old 03-04-2013, 06:34 PM
bygddy bygddy is offline
Proud LOSER
Originally Posted by 1Gary View Post
How about it guys??. Now sonic checks don't work.I do think a second opinion is in order here........
He didnt say they don't work, he said you wouldn't see anything....they don't crack often....they key word was budget......in BOLD ......therefore if they are stock 4v pistons, likely 12cc dish, use felpro 1094, and after unshrouding for 194's you hopefully will be right around 61cc's. I just did set for a friend last month and he actually took the time to CC them, ranged from 60 to one just a hair over 61. Should put your comp just shy of 10.1, like 9.8 Ish......if your porting job was good, it will breathe enough to use your cam choice, and with lots of gear and converter will run like a rpd ape.....will it go 12's? Who knows....could pretty easily.....and it will be a blast, for very little money. And not be a grenade......there's another opinion......
