Alright so i have a 350 in my 1984 2500 and im looking to get some more power out of it mostly low end torque and hp being its a truck and whatnot. Right now its mostly stock besides headman headers and true duals, performer intake, 650 cfm thunder series carb. mallory ignition, taylor wires. its got a Th400. and a bunch of shiny go fast engine parts the last guy threw on there.
Im looking at doing a budget vortec head swap and i had a few questions. Im looking at doing this as wallet friendly as possible. Alright so here goes.
i can get a set of vortec heads for around $300 off craigslist or hopefully even less than $200 if i go to a junkyard and pull em myself.
if i dont get big cam will i be able to keep it out of the machine shop and having to upgrade the valve springs and all that? i was thinking the edelbrock performer truck cam and hydraulic lifter kit.
http://www.jegs.com/i/Edelbrock/350/...rentProductId= or mabye even just keeping the stock cam if that would even work? i want to keep a smooth idle as this will be my daily driver(i dont drive much) only to school and work 5 miles away
ill need new valve covers right? or mabye use the stock vortec ones
I know ill need new gaskets and all that
will my pushrods work or will i need new ones?
I know ill have to ditch the performer intake. i can get a edelbrock nock off vortec airgap intake new for around $150 or mabe find a used one.
My headers should bolt right back up though right?
now i heard you can end up with to much compression with a vortec swap. if i have a very mild cam like the one above i should still be able to use pump gas mabe even 87 still?
im sure im missing things but just want to know everything that i will need for the swap. Thanks
