a budget 383 stroker build using a stock 400 GM Crank - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-13-2007, 05:52 PM
Mustangsaly's Avatar
I have acquired a GM 400 cast crank, I want to build my son a budget 383 stroker. instead of using the 5.565 rods and 350 pistons, can I use 5.7 GM factory rods and 383 pistons with a 400 balancer and flexplate ?
or can I use a 350 unbalanced flywheel and one of these plates ? (pic below) if the plate is used, can I use a 350 balancer instead of a 400 balancer & a unbalanced flywheel with a GM 400 crank ? or a 400 balancer is needed with the plate and a unbalanced flywheel ?
if I use that plate, do I need to take the balancer and the plate & flywheel in with the crank and pistons & rods to the machine shop to be balanced ?
just the mains on the 400 crank need to be turned down to fit in the 350 block ? I realize that theres probably going to be block clearancing and maybe rod clearancing.
theres prob better method's to build 383 than this. but whats your opinion on this method ?
Old 10-13-2007, 06:25 PM
GMC boogie's Avatar
Just me but, I would go for a new SCAT 9000 series stroker crank for $189 plus shipping. The stock 400 crank will require the mains to be turned down .200. Not cheap at alot of machine shops. The 5.7 rod Scat crank will need a 400 style damper and flexplate for balancing. Never used the balanced plate before but it looks like it is made to use with a neutral flexplate.
Old 10-13-2007, 06:35 PM
Notorious's Avatar
Hot rodder, not street rodder!
Ditto. Using a factory 400 crank in this day and age is just beating your head against the wall. Stroker kits of (at least) stock quality are available for around $700 or so, including crank, rods, pistons as well as rings and bearings.
Old 10-13-2007, 09:34 PM
is made to be used neutral flywheel.
Old 10-13-2007, 09:55 PM
GMC boogie's Avatar
It will work with either a flexplate(auto) or a flywheel(manual)
Old 10-14-2007, 05:25 AM
Hippie's Avatar
Last journal entry: HEI comparison.
Unless you have a good buddy that works in an automotive machine shop sell the 400 crank to someone building a 400 and just but a Scat or Eagle crank. You can get one of their cast cranks for what it will cost you to have the 400 turned. Better yet buy the complete rotating assembly as a kit, you'll wish you had before you're all done trying to piece everything together.
Old 10-14-2007, 06:41 PM
well I don't have a good buddy that works in an automotive machine shop. I will look into a Scat or Eagle crank. and look at complete rotating assemblys as a kit.
thanks
Old 10-14-2007, 09:56 PM
F-BIRD'88's Avatar
Yada Yada Yada
Find a 400ci 2 bolt block to go with your 400 crank and build a real motor.
406ci with 5.7" rods. Yes it will need to be balanced.
Old 10-15-2007, 12:57 PM
Last wiki edit: Calculating tire size
Last journal entry: Changes...
Wiki Edits: 2
When you get your stuff balanced bring every little piece in with you. I wouldn't use that balance plate because it will introduce more chance for wobble in your flywheel and will move the ring gear location relative to the starter. I got a scat 383 kit with forged pistons and 5.7" rods and it almost internal balanced, but needed mallory to make it so I went external. I got a new jobber flywheel for $100 online, and a professional products 8" balancer and its all good now.
Here's where I'm at with my 383 build Malibu73 Engine 17 12-06-2009 08:56 PM
5.7 in. rods with stock 400 crank? Warrant Engine 6 11-03-2006 07:37 PM
383 Stroker Build! Hypereutectic or forged aluminum pistons????? 89SDime Engine 12 09-08-2005 07:08 AM
scrap 400 build 383 6speedwagon Engine 4 10-19-2003 03:11 PM
383 on very tight budget stereodud Engine 13 01-15-2003 02:33 PM
