Budget 454 rebuild w/peanut heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2005, 03:41 PM
Rhansen's Avatar
Footbraker
My uncle has a 454 from an 81 chevy truck (236 peanut heads) that he's wanting to rebuild for his 87 Monte Carlo SS. The plan so far is to re-use the crank, rods and heads, and purchase new pistons, cam, intake, etc...
Those heads are a limiting factor and I was wondering what kind of rpm those heads would allow?
I was thinking that a Crane cam #133941 (216*/228*, .515/.510 lift) with around 9.5:1 cr would work allright, but I am not positive. Any suggestions or advice is welcome.
Rob
Old 03-22-2005, 05:33 PM
firestone's Avatar
http://teamrfc.gospelcom.net
As you know, that head is not a performance head. If you are looking to build a motor that gets decient gas mileage for a big block, and is good for a daily driver, but performance is not important this would be a use for this head. As far as your cam goes, I think it may be a little large for what the motor is going to be good at. The cam you are looking at will make a little more power than a smaller one, but overall, the motor would still not make very much hp. I think your best bet if you want to stick with those heads would be to buy a cam like the XE250H (206 212 @.050 .470 .475 lift 600-4800 RPM) along with a performer intake. This way, you would be getting the best gas mileage possible, and you will pick up some low end torque, which is where these heads will perform the best. Going with a bigger cam will probably make a little more hp, but at the loss of gas mileage, and I dont think the gain in hp would make the loss in gas mileage worth it. Another idea would be to save up for a set of rebuilt 049 or 781 heads. These are a great head to start with for more of a performance build, and a larger cam would defanetly make considerably more hp. Below is a listing of the flow numbers of your heads compared to some 049's.
Yours, peanut 236
http://www.chevyhiperformance.com/techarticles/41598/index7.html
049
http://www.chevyhiperformance.com/techarticles/41598/index8.html
here are some 049's for sale
http://www.racingjunk.com/exec/ca/view/384343/049-Heads.html
Good luck,
Adam
Old 03-22-2005, 07:47 PM
Rhansen's Avatar
Footbraker
I don't think that mileage is a concern - it's just going to be a weekend cruiser/bracket racer on a tight budget. Trans will either be a TH400 or a TH350 (leaning toward the TH350 but already have a TH400), stall and gears are as yet undetermined.
Better heads are always a good idea, but did you reccommend the smaller cam based solely on mileage or because the heads don't flow enough to rev to 5k?
Old 03-22-2005, 08:06 PM
firestone's Avatar
I recommended the smaller cam because I think that is where those heads will like to run at. I cant say for sure that the heads will or will not go to 5000 RPM, if I had to guess, I would say probably, but that would be about the max. Keep in mind that set of stock 170cc (yours are 208cc) small block vortec heads outflow the heads you are looing at, and they will only pull to around 6000 max on a small block 350. The thing is, I think you are probably talking about the difference between around 230 hp or 250 hp, but more low end torque with the smaller cam. Either way, that is not very much hp, so I was saying why not go with a little more torque and gas mileage rather than a little more hp? I think the engine is better suited for the smaller cam with those heads.
Adam
454 heads Will's41 Engine 0 01-26-2003 08:36 AM
rebuilding 454 budget of $1,600 72 Z28 Engine 1 12-13-2002 09:03 AM
cost of a 454 rebuild? ratfink14 Engine 1 12-12-2002 12:05 AM
rebuild a 454 madmax2 Engine 2 12-04-2002 08:45 AM
454 Heads Junk or keepers? roys63 Engine 3 11-12-2002 07:03 PM
