budget 500hp 360sbc - Page 5 - Hot Rod Forum : Hotrodders Bulletin Board
  #61 (permalink)
Old 12-09-2012, 04:12 PM
dart heads tend to run higher combustion chamber wise than advertised. so assuming that's the case with those heads, even with a light milling, they are probably near 70cc. a typical 5cc valve relief piston and zero decked block with a typical gasket would put you more in the 10:1 range, not sure where you are getting 12:1 unless planning to run a dome.
that said, and knowing what the heads are and experience and budget constraints, here's what i would recommend.
forget 500 hp. like i mentioned early on, most people have no idea what they really have and if you build for 400 you will be ahead of what most make.
as mentioned earlier, find a set of speed pro forged pistons, find some with the 2 valve reliefs as the four relief are pretty shy on relief depth for serious cams.
scat 9000 series crank and a set of i beam rods will make a durable bottom end that you could later upgrade or throw nitrous at.
solid flat tappet cams aren't worthy of bragging rights much any more but the performance is good still and pretty cheap. same with solid lifters vs. high end hydraulic lifters.
  #62 (permalink)
Old 12-09-2012, 05:52 PM
hcompton's Avatar
Old & Furious
I think the heads you got are fine you will want to cc them to make sure your compression is high enough to make the power.
That being said you may be held back to 400 hp with those heads. To make a straight 500 hpuppies. Here is a set of heads that will do the job of hitting 500 mark. If you got the bucks if not build what you got it will not be flat you will be damn happy with 400 and some options for the future. Here is a link to dart pro 1 that will run the number think about the 210 or 215 cc intake heads fully assembled for high rpm engine are about 900 each. In your postion i would not buy these but they are the right ones for the job.
Pro1 Small Block Chevy Cylinder Heads - Small Block Chevy Aluminum Heads - Cylinder Heads
Do you want to sell the cast pistons? Or heads for that matter. If unused i would interested in both. Wait until you are ready dont sell off too soon of course, i will still be here.
  #63 (permalink)
Old 12-09-2012, 07:37 PM
I just got done cc' one chamber and it was around 70. I know I should have done all 8 but only had time for one. That is a little bit of alcohol came out of the too of glass, so rough est. Would be 70cc's.
And yes I would sell heads, rods, and pistons, maybe trade a combo of those parts for some aluminum heads. Or some parts that would do me good. I just don't want to be stuck without anything.
Oh yeah I forgot to mention I do have a PONCHO 400 sittin right beside the SBC. it also needs rebuilt
  #64 (permalink)
Old 12-09-2012, 07:40 PM
hcompton's Avatar
Old & Furious
I got a 455 crank in need of a 400 any where near md?
  #65 (permalink)
Old 12-09-2012, 08:47 PM
Southern IND. :/
every time i walk out to the garage that poncho yells my name lol it
and i may be interested in that crank.
  #66 (permalink)
Old 12-09-2012, 08:58 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Sounded more like he wants your block... in any event not to be a buzz kill, you'll be better off taking this to PM.
  #67 (permalink)
Old 12-10-2012, 07:00 AM
hcompton's Avatar
Old & Furious
block is too heavy to ship let me get the crank out and see if its any good been wrapped up for a few years. I like pontiacs but they cost too much for me. I would rather go small chevy for most apps.
PM me for more info thanks.
  #68 (permalink)
Old 12-10-2012, 09:01 AM
The cost is the reason I'm building the SBC and not the pontiac.
500hp 383 underdogidi Hotrodding Basics 13 03-27-2012 06:01 PM
360/500hp ? duster75 Engine 14 05-17-2011 06:44 AM
How Do I Get 500hp novacrazy2007 Engine 27 06-16-2010 06:54 PM
Best 1,500HP Sleeper ever!!! TorkMonster400 Hotrodders' Lounge 5 09-26-2009 03:40 PM
one of the secrets to a budget 500HP ap72 Engine 40 11-19-2008 11:29 PM
