budget bracket racer - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-07-2008, 12:19 AM
Okay, I have an '81 shortbox with a stock 350 bottom end. vacuume secondaries carb, performer rpm intake, gear drive, headers with flowmasters, and a shiftkit. The cam is hooped and needs replacing so I figure I might as well change the heads now and buy a cam to match. What would you recommend as an ideal head and cam setup, yet cheap and what cam would you run with it? Right now I have swirl port heads that are a bear to hit 4,500 and it has a huge cam but the #4 exhaust lobe is round. Also, I currently have 3.08s in the rear, what would be the recommended gear for the 1/8 mile? The 3.08s may not be too bad but I'de probably be in first the whole way. I still want it to be streetable as it's my daily driver but I live in a small town and only drive a few kms to work every day. Open to anything... looking for ideas/suggestions/best bang for my hard earned buck! Thanks a lot
Old 11-07-2008, 01:03 AM
victoria eh, do you need aircare on the island? cus that will knock out alot of cam choices, unless you have someway of getting around that.
Old 11-07-2008, 01:04 AM
They have aircare in Vancouver but not on the island
Old 11-07-2008, 01:07 AM
oh right on, aircare sucks for hotrods, that will make things easier for you then.
Will Rear Disc's Stop Better Than Rear Drums?? acr Suspension - Brakes - Steering 90 10-25-2012 08:01 PM
Caddy Brake Fun & Does Line Size Matter? Help Needed. bigfred1958 Suspension - Brakes - Steering 5 04-06-2006 09:20 AM
Dual Master Cylinder Brake Pedal with Balance Bar iceman36 Suspension - Brakes - Steering 6 02-24-2006 01:55 PM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 07:17 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 04:34 PM
