Budget build list of parts - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-28-2011, 07:00 PM
goldenbullet44's Avatar
User that registered
This is a budget build im doing or gonna do
Gonna list the parts you tell me what you guys think.
Rotating assembly.
http://www.summitracing.com/parts/ESP-B13403L03068/
top end kit.
http://www.summitracing.com/parts/SME-K-355-400/
The block
http://www.summitracing.com/parts/SUM-150100/
oil pan
http://www.summitracing.com/parts/SUM-G3503X/
Rockers
http://www.summitracing.com/parts/SUM-141506/
Carb
http://www.summitracing.com/parts/EDL-9907/
oil pump
http://www.summitracing.com/parts/MIL-18756/
oil pickup
http://www.summitracing.com/parts/MEL-55-S1/
missing timing chain cover i have a budgett of 3600 bucks tell me what you guys think about this combo..
Thanks
Old 06-28-2011, 07:03 PM
you could build a 383 complete for less including new block
Old 06-30-2011, 01:25 PM
looking at compression with those heads and that rotating assembly if im correct isnt that 14:1 compression?
Old 07-04-2011, 06:19 AM
piecing an engine together like that is very expensive.
If you are on a budget, use Craig's list in your area and buy a complete 96 to 2000 350 vortec engine from a truck.
Get a complete engine from fan to flywheel in running condition. It is important to get a COMPLETE ENGINE as the little things will nickel and dime you to death!
This engine has a factory roller cam and vortec heads. Makes 280hp in stock form. Add headers and a little bigger cam and it can make 350hp easily while still retaining a good idle. Can make 400hp with a lopey cam and more compression.
Do a simple rebuild, modify the heads for more lift, and add a bigger roller cam. Should cost less than 1000 to rebuild a 350 engine with new pistons, bored and cleaned, bearings, oil pump, timing chain, gaskets, and valve job. Will cost another 250 if the machine shop does the assembly.
You may find an engine in good enough condition that will not need a rebuild then add some bolt ons and go.
read this.
http://www.superchevy.com/technical/...ild/index.html
New SBC 383 build question + parts list Filmjay Engine 40 04-25-2010 09:25 PM
Tri 4-bar...parts kit/list? LiftFlat Suspension - Brakes - Steering 2 09-16-2007 06:29 PM
Parts list? 1nastysnake03 Engine 4 08-31-2007 09:48 AM
do it right the 1st time, strong 400 short block budget build, stock parts? Warrant Engine 9 12-04-2006 07:29 PM
Parts List Mav Engine 2 04-24-2003 05:47 PM
