budget chevy 383 build - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2012, 04:53 PM
Hello everybody doing a budget 383 build $2500 to $3000 for parts have 1972 4 bolt main 350 block with pistons rods crank heads figure can sell the heads and crank as builders just use block and possibly rods ? Going in a 1974 Chevelle 342 gears 28 inch tall tires turbo 350 rebuild with heavy duty stall and trans go 2 shift kit. have 1 5/8 headers with 2.5 inch duals with flowmaster mufflers. Was hoping for 400 to 450 hp and tq. Will be 99% street driven.
Want to run power brakes vaccum advance carb Holley 80508S-R open to suggestions? Edlebrock rpm air gap intake. Howards cams 113215-10 or 110245-12 or open to suggestions biggest with stock stall? with Dart SHP 200cc 72 cc chamber heads or Patriot Freedom 190cc 64cc chamber open to suggestions? Was thinking about a Scat 9000 rotating assembly? Looking for recommendations cam heads compression whatever I missed. Thank you Tim
48 chevy budget build budgetcruiser Transmission - Rearend 2 10-06-2011 01:01 PM
Budget 400 SBC build up elcamino74ss Engine 15 02-02-2011 08:22 PM
350 build on a budget MonteMan8686 Engine 6 03-24-2010 10:40 PM
sbc budget build 79monster Engine 4 10-29-2008 08:21 AM
283/327 Low Budget Build?? oklowride Engine 12 09-11-2006 12:03 PM
